Tyre Valve Extender Brackets (1 Viewer)
Edgie
96
5
Taunton Somerset
Hoping some of you out there have some close up pics of your twin wheel valve extension brackets????? have bought some valve extenders and brackets and would like to see others before I attempt to fit..
Thanks in advance
Edgie
American Dream
156
Lincoln
Cheers Edgie.
Did you get the rigid or flexible ones?
I'd like to see how they are fitted too?
Someone said they didn't rebalance the wheels after fitting.
I would have thought that was necessary?
Edgie
Edgie
96
5
Taunton Somerset
Got flexible steel covered in rubber by Michelin and the twin wheel mounted bracket, thing is I have chrome trims and am keen to see how others have theirs fitted..... com'n guys and gals the rain has stopped pop outside with your digi cams :winky:
Feb 22, 2008
12,266
45,055
Nearly Tugging
Hiya Edgie
just took some pics of mine, the outer screw on one is self explanatory, the inner bracket one has two ssteel claw type parts that clamp and is tightened over the edge of the hole in the outer wheel.
On my last rv the brackets were pop rivetted to the centre of the wheel trim on the outside, sorry no pics of those,
hope this helps Larry
Edgie
Edgie
96
5
Taunton Somerset
Thanks Larry really appreciate you doing that :thumb: sadly they are not the same as the ones I have bought, see pics attached.... anyone else got any pics...
43,332
49,512
Any good.
fitted to my ford chassis rexhall.
attached by small rivets through the stainless liners.
Feb 22, 2008
12,266
45,055
Nearly Tugging
Not seen those before, in the absence of any other retainer for the extension tubes I think that the clamp would be fitted to wheel perforation with the narrow end of the wire supports outwards so that the centrifugal force of the wheel keeps the valve extenders located.
Larry
Apr 19, 2009
246
112
Rotherham
RV
got them fitted on one side,but not the other.Anyone know how to get the ss trims off, mine seem realy tight fitted.
American Dream
156
Lincoln
That would be useful.:thumb:
Got a pair of new tyres to get fitted soon and I really don't want them to damage the covers.
Steve
slobadoberbob
6,151
1,960
Kent, garden of England
Winnebago 23' something
25 years & counting
had a major problem with them - lost tyre
Thanks in advance
Edgie
I got a set for my Winnibago Aspect from Darren at Motorhome Medics. Seems there are some issues regarding the type of valve they are going to be fitted to. I checked them out also while in the USA at Camping World store in San Dieago and was advised against them as I could not state what type of valves I had. They seemed to think you needed to have the actual valve changed as well.
Anyway did not get them from the states, I purchased them from Darren. I had my local heavy lorry repair company fit them ... they are a main Renault truck dealer and the owner runs 9 American wreckers and a lot of other makes, a real yank nut. Has a Winnibago himself.. Mick Gould Commercials in Goudhurst Kent. I have used them to fit my air lift and lots of other jobs including the pre MOT's they are a big concern.
I had the valves fitted (ÂŁ40 labour) and went home. I run a tyre flat and yes it was the valve, it had not been done up properly. So the extender valve was bleeding off the air (inside wheel)... by the time I got home I had a flat tyre that had run 20 miles.
I called out a tyre rescue (as sold in various magazines - they turn out, you buy the tire sort of thing...waste of time.. took 3 days and 3 visits to get a new tire fitted). Anyway the tire call out company in Kent - Watling Street Tires, fitted comercial valve extenders (they had to put new valve in the wheel).. they also removed the other valve I had on the inside on the otherside as they thought that was not done up very well... he, the fitter says you need to remove the wheel to do the job and not fit it on and poke it through as it can come un-done (as this is the case on mine). Now I have my rears both done and they have clamped them to my wheel liners. I can inflate inner and outer from the same place on the outside of the tire 180 degree across from each other.
I, in the end invested in a Stanley Bostick (from Screwfix) air compressor and a comercial airline to check and pump my own tires up as I found even getting the tires done was a problem.. as they have 65 psi on the front and 60 psi on the rears. - that is all I wanted to do in the start was to be able to check the tire pressure.. what a mess.. the replacement tire cost ÂŁ240 - but after much agrument I ended up paying just the ÂŁ40 for the tire valve fitting and cancelled the remainder of the 3 year call out contract (no refund)..
So be warned. - also the fixed angle type are a real pain... go for the flexible type or find your local truck tire company and they will have the comerical type that fit American RV's
Bob:thumb:
Soundman
69
West Yorkshire
16 Years
Euroliner Trims with Valve Extenders
Euroliner Trims with valve extenders
Soundman
mike/jen
37
12
Powys
RV
7 years
Trims
Hi Andy when you get your trims off make sure you put copper grease in the cap before you put them back on, and only just nic them up. i hope this helps.
Mike
H
Hagstrom
Sorry this may be a bit off-topic. We have the same Euroliners fitted to our van but used the spring clip option to retain the flexible tyre valve extenders instead of the US bracket kit.
However, I see from Soundman's wheel photo above that he has Michelin Agilis 215/75 16?s fitted to what looks like a Sprinter 518 (Hymer S820?) chassis and wanted to know how he got on with them. (I tried to start a "Conversation" but that option is not available on his profile.)
I'm asking because my Sprinter 518 handbook specifies 205/75 16s to be fitted to dual rears models and I would like to beef up the tyres when I replace them soon. I had assumed that 205s were the maximum in case the dual rears started rubbing together under load conditions? It would me give confidence to fit 215s - especially knowing that Hymer provided them as standard from new, as they would not depart from manufacturers recommendations without thorough grounds.
Norman
WSandME
368
453
Wigan-ish
Hymer B660 Bestline
SInce 2006
I'm not sure whether it's proper to resurrect a topic, but I'd like to know from users of tyre valve extenders on dual rear wheels whether you need to re-balance the wheels.
I'm considering adding braided steel flexible extenders to both the inner and outer wheels and fixing them to a bracket or brackets to allow them both to be accessed through the wheel trims.
It occurs to me that if the mounting hardware is fixed to the outer wheel, the weight of the extender from the inner wheel won't be there when balancing - presuming the balancing must be done on individual wheels off the vehicle.
How is balancing done - if at all?
19,368
30,330
Your two valve extenders will oppose each other on opposite sides of the wheel so should be OK, I run TyrePal sensors in the pipe work and just keep them opposite each other behind the wheel trim and have no problem.
43,332
49,512
As already said....put the inner wheel on then the outer with the actual valve as close to 180° opposite the inner valve.
That way one extender counterbalances the other one.
The few grams difference between inner and outer extenders won't make any noticeable difference when driving.
dabhand
4,307
23,936
Staffs
Concorde carver E35
Since 1993
Flexible or solid? Brackets or not? Any ideas on the best type to use with tyrepal? No hijack intended, cheers.
canopus
6,139
10,264
rural Lincolnshire
Carado CV640 Pro
Why don't you take your van to Grantham Simon. The firm that supplied Martin (funflair) are at Gt Gonerby just off the A1, not far from us.
WSandME
368
453
Wigan-ish
Hymer B660 Bestline
SInce 2006
Thanks, guys,
I hadn't noticed whether the valves were on opposite sides - I'll check to ensure they are and set up the hardware to be as precisely opposed as possible (y)
19,368
30,330
Simon @dabhand has asked me for some photos of the flow through monitors in situ so here goes you might as well all have a look if you are interested. (Please excuse the rusty wheels I have had the fronts powder coated but not the rears yet)
IMG_8714.JPG This is how the valve end of the final extension pipe come through the trim.
IMG_3075.JPG The big steel bracket is for the trim to bolt to, the tyre pressure monitors are cable tied to the wires around the bracket to stop them flinging out with centrifugal force.
IMG_0158.JPG The outer wheel of the two rears has a 90 bend at the end of the pipe to come from the valve as the wheel is essentially on backwards so the valve is the wrong side of the wheel.
IMG_1218.JPG The front could have a standard pressure monitoring cap on the valve depending on the trim, ours is piped up similar to the rear partly because the trims were already drilled and had the extender pipes through so I just put the pressure monitor inline.
Duck Truck
1,203
1,226
UP North
Hobby 725
Errr
just to add.
I fitted coloured valve caps to match our van.
DON'T do the same
They were made of alloy
and corroded after the winter and getting them off to check the tyre pressures was a night mare.
Stick to the plastic ones
kev
19,368
30,330
Errr
just to add.
DON'T do the same
kev
I always use a bit of Vaseline, on the cap threads as well.
