Tyre pressures (1 Viewer)
kelv
672
895
leicester
Carthago 145
just been to the local garage to check my tyre pressure not a chance of getting near the airline with a motorhome so of to the next garage put my twenty pence in and only managed to check two tyres into the shop for a twenty pence piece stood in the que for 5 mins back to the van finished checking tyres.
after such a palaver putting air in decided to buy my own inflater any recommendations on which one to get with a long lead to reach all wheels.
19,369
30,349
Go to your local cycle shop and get a track pump, will reach as far as you can walk and will take a tyre from flat quicker than the noisy electric ones, Max pressure about 150psi.
Badknee
7,408
412,986
notloB
Vantage Neo
Living the dream.
I use one of these, or a Clarke one would do the same job from Machine Mart.
kelv
kelv
672
895
leicester
Carthago 145
Never even thought of a cycle pump I will have a look
Jul 29, 2013
9,071
18,564
Salisbury
Hymer B678DL A class
I bought a nice little pump from Maplins I think it was about £30 and it will pump to pressures above what you'll need
Jul 29, 2013
9,071
18,564
Salisbury
It was a metal one not the ring plastic type they were on offer at the time.
Southampton
522
318
Hampshire
I got one from Halfords the RAC900 works a treat and gets mine to 80psi no problem. I now run at 70ish after advice on here.
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
Our van came with a fix & go kit which includes the compressor I use.
kelv
kelv
672
895
leicester
Carthago 145
Just googled looks a great bit of kit long lead perfect.
do you connect to leisure battery or starter battery
Southampton
522
318
Hampshire
I have a fiat Ducati tag axle and connect to the remote terminals of the vehicle battery under the bonnet. The air hose easily reaches all wheels
GWAYGWAY
4,213
3,306
Dover
Hymer ML I 580
4 years
When you look inside some of these little 12V compressor you find a tiny motor driving a model aircraft engine or very similar sized compressor, about 2cc or thereabouts, no wonder they take so long to pump up a big tyre.
