gerry mcg
Michelin recommended 65psi front / 80 psi rear for my 3500kg PVC with a 1650kg/1850kg F/R axle weight distribution on 225/75/R16C/CP Q 116 a Agilis Camping tyres
This was their reply
The Agilis Camping tyre boasts a long life by using the same technology as the Michelin Agilis van tyre range. It has a reinforced construction to enable the use of higher pressures, has 8 kerbing protectors built in to each sidewall to increase resistance of sidewall scuffing and is M+S (mud and snow) marked to give sufficient grip when occasionally travelling in difficult conditions such as unsurfaced roads, mud and snow.
The suggested tyre pressure for the rear of a motorhome running on the Agilis Camping is 80psi. This is due to the construction of the tyre with 2 casing plies enabling the use of higher pressures. Its construction and the use of higher pressures is designed to cope with continual heavy loads sometimes found on motorhomes and can help with wear pattern issues if lower pressures are used particularly on the rear axle.
The front pressures however can be adjusted according to accurately weighed axle loads for a more comfortable ride and optimum performance. We at Michelin recommend 65psi to start with.
