Twin rear wheel chassis - pros & cons? (4 Viewers)
Dafydd
111
102
St Davids, West Wales
Frankia on order
Of the vans I'm looking at for a 2015 purchase one is on a MB516 with twin rear wheels - the equivalent of the Fiat tag-axle for a GVW of 5 tonnes.
(I'm looking for a MH with a large payload over the standard MIRO for long-term touring).
Besides the extra tyre costs (I assume) involved with having 6 wheels what other things should I be considering from the point of view of day-to-day driving and maintenance?
Increased fuel consumption? Difficulties with checking/topping up tyre pressures? Can snow chains be used?
The space, storage and payload are the advantages of a 5t (7.6m) van but what are the downsides/extra considerations that I need to be aware of given the extra set of wheels necessary for the weight?
Any thoughts appreciated.
BreweryDave
3,495
10,542
Alvor, Algarve
None now!
My thoughts (having a Fiat tag) are that if you need the advantage of the extra payload, then you have no choice.
Therefore the only downsides are - you can't have a smaller motorhome.
A tag is very stable, you are looking at the merc with twin wheels on the same axle, which I had on an RV. No real difference - as it's on a twin axle instead of a triple axle - to give you the load carrying capacity.
Obviously - tyre wear will mean 6 tyres instead of 4, and the increased weight of a 5 T van over a 3 T van will mean its greater - but if what you want and need is a large payload - then these things are irrelevant.
Feb 22, 2008
12,266
45,062
Nearly Tugging
The other advantage of the twin rears on single axle is it will be rear wheel drive and as a result much better traction on wet grass, snow etc as most of your weight is over the drive wheels .
hdvrod
859
733
devon
since jan 2011
On twin wheels you have a valve extension to check the inner tyres.
19,377
30,375
Deffo better traction with 4 wheels on the one rear axle especially if you get it with diff lock, fair chance your tyres will be old before they are worn out but will wear better on the single axle variant as not scrubbing when dragging the tag axles around corners.
Getting at the tyre valves is no problem as you can run a pipe from the inside wheel to wherever you want it.
Don't know about snow chains but I would guess just fit to the outside two wheels
Feb 22, 2008
12,266
45,062
Nearly Tugging
Yes I have snow chains for mine but never needed them in anger
Jean-luc
104
69
Rapido 963F
A friend of mine with a Hymer on a Merc twin wheel chassis ended up on a Aire on which fell a few inches of snow overnight. After breakfast he just set off using the diff-lock and passed half a dozen others unable to negotiate the uphill exit. He has also towed vehicles off rally fields.
From a traction point of view a rear drive twin wheel set-up with diff-lock is far far superior than front wheel drive.
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
Another, perhaps minor, advantage of the twin rear wheels over twin rear axles set-up relates to touring in France. It has been reported that some French campsites will not allow twin axled caravans or motorhomes; it's a way of banning travellers (gens de passage) who often use twin axle vans, without appearing to discriminate against a specific group.
This may not be a big issue for you but as an example, here is an extract from the site details for Amboise municipal site in the Loire valley.
Spanning an area of 3 hectares, the local campsite of Amboise, rated 2 stars, has 300 sites, mostly shaded and very spacious to accommodate tents, caravans and motorhomes (with the exception of double axles).
StefAndDi
408
931
Near St. Austell, Cornwall
Ceased motorhoming 1/3/16
2010 to 2016
I'm really pleased to read your post as my new MH will be a Hymer with Mercedes twin-wheel rear axle.
Stef.
ASel
32
32
Gretna
A TAG axle MH will be class 4 for tolls in most European countries but twin wheel back axle MH will only be class 3. See here http://www.autoroutes.fr/fr/classification-des-vehicules.htm
We had a 4.5T TAG axle Fiat and the traction was so poor that on one occasion we could not set off at a junction as the gradient was too steep and the wheels just spun, this was on a dry road.
Dafydd
Dafydd
111
102
Frankia on order
Thanks for all the replies, very reassuring. Rear wheel drive is one of the reasons I'm leaning towards MB.
Three years ago (when my MH research started) I was looking at panel van conversions, then semi-integrated and now I'm settling on a 5t monster (and a bill to match)!
Thanks too to @Judgemental who made me seriously consider payload for long-term touring - you were right, the La Strada is far too limited. When I add up the weight of optional kit, my stuff, companion & their stuff, food, booze and kitchen stuff, birdwatching stuff, camping furniture, bicycles, winter stuff ... it's several hundred kilos so I'm only looking at (A class) with >800kg above the MIRO.
19,377
30,375
I reckon the IVECO is a pretty good chassis and certainly good for weight as they can go up to at least 7.2t, if you are buying new you can now get the ZF torque converter auto which has to be an improvement over the older Agile robotic auto. I think more converters are using the IVECO than the Merc.
trekkin
332
490
Staffordshire
Rv
5 years but still learning
A lot easier to level a twin wheel axle using chocks or ramps, have seen some scary sites where owners have only used one ramp on a tag axle, one wheel on the ramp one on the ground, just looks wrong.
Tags are more stable on the road but often front wheel drive, on the soft grass one wheel follows in the rut of the other whereas a twin wheel spreads the load across the van and as said better traction from rear driven
Horse for courses, but seems you have got your requirements sorted so the rest will follow.
Feb 24, 2013
13,090
101,510
Bolsover, Derbyshire
Hymer S800
not long enough
Is the diff lock an option? is it likely to be something I have and don't know about? sounds very useful
To OP, I have a twin wheeled rear axle, gives us a long over hang on an 8m MH but had no issues at all with traction in 2 years, valves have extensions on for checking / filling
19,377
30,375
Hi David
I think you will have what they call ABD auto braking differential which uses the braking system/ABS sensors to brake a wheel that starts to spin thereby putting the drive to the other wheel. The good news is that it does this by itself so you don't need to look for any switches.
Now you just need to go find some snow and see if it works.
JeanLuc
3,304
2,199
Warwickshire
My Hymer is on an older Sprinter than yours David (2003 316 5-speed auto). It has an ESP programme that does what 'funflair' is referring to. Yours may be more sophisticated than mine but it may have limitations. It is a great safety tool under normal circumstances; e.g. it will correct minor wheelspins in snow. However, it is not as useful as a proper diff-lock or limited slip diff in the real goo. (My all-wheel drive Subaru Outback has the latter and the traction is amazing.) If the motorhome is stuck in really slippery mud (has only happened once) the ESP first slows down the slipping wheel, then the other one as that starts to spin. Power to the spinning wheels is reduced progressively to the point where the engine virtually shuts down. At that point the only option is to get out the folding shovel and dig, and/or let down the tyres significantly.
flatpackchicken
1,277
1,757
BICESTER OXFORDSHIRE
A Class Frankia I8000
Since nov 2009
Rear wheel drive with a twin tyre each side axle seems to be the best set up that you can get,, as a lot of weight goes over the back axle especially when you have quite a big overhang such as mine on an 8.2m mh, and I put it to the test this winter coming through France about 50km before I got to the Millau bridge:france:, as I was about 1200 mtrs up on motorway and had snowed about 6" and police was dealing with a small accident van and car, so I had to stop as was right in front of me, and French mh pulled up alongside of me (normal fwd Peugeot) and when we could go the French man could not get going again and the police were trying to get him into the side, maybe to check if he had snow chains, but I with my finger poised on the diff lock button just pulled away and did not need the diff lock (result although as virgin snow by this time), and did not need my snow chains either, double result,,,, although if it had not started to clear as I started to descend I would have put my snow chains on for safety , overall very impressed with RWD (rear wheel drive) and have had no problems anywhere so far in getting of wet grass or slippery inclines, (although I am ready to pull Sundowners:notworthy2: out now always will be grateful for there Beast:notworthy2::notworthy2::notworthy2::notworthy2:) all in all would never have a FWD again if I had a choice.
Regards Garry Flatpackchicken
Judge Mental
Sep 2, 2009
6,650
5,883
Sarth London
Possl 636 FR panel van
1994 and beyond...
Thanks :) I know I can get a bit evangelical and go on a bit.... But weight and quality of construction often gets forgotten about when looking at the choice between all these big shiny boxes.
Believe me, like most thing's its what's under the skin what really matters :)
Peter A Forbes
270
184
Rushden, Northants, UK
Mercedes 614D
You are really into truck terrotory at 5+ tonnes gross weight, and the general construction is much more solid underneath than many vans.
The big Ivecos are very good as well, they go up to a 7.5 tonner as did Mercedes with the Vario (now out of production)
Ours is 5.9 tonnes gross, just under 4 tonnes empty.
The only thing we have done to the running gear is to upgrade the tyres from 215/75R16C to 225/75R16C, load ratings appropriate to the axles, 121 on the back and 118 on the front.
The rear axle in ours is plated at 4.3 tonnes but is in fact a 5.6 tonne axle as used in the 814 7.5 tonne Vario.
Peter
BreweryDave
3,495
10,542
Alvor, Algarve
None now!
It's just a shame that the merc heavy chassis is now not readily available from many manufacturers. For me - layout and payload are most important so am sticking with the fiat tag for my next new van - have one now and touch wood never got stuck - and being mindful of the FWD will always avoid the risk!!!
Judge Mental
Sep 2, 2009
6,650
5,883
Sarth London
1994 and beyond...
Fiat traction + makes a real difference getting off sticky stuff......
Bertie Bassett
2,743
8,702
since 1988
Dafydd, Happy New Year. You have mentioned elsewhere that you will be going north into Scandinavia. Now you are considering a larger vehicle it would be worth sketching out your travel budget as road tolling/ferries and some tunnels, particularly in Norway work out extremely expensive over 3.5T. Tolls aren't cheap at that weight but over it requires a bit of planning imo fwiw. (Unless you've won the Irish Lottery:xrofl:)
Dafydd
Dafydd
111
102
Frankia on order
Happy New Year to you too Bertie! ... Hic!...
I've done some research into budgetary implications. I have a provisional annual budget that includes a "Norway savings plan" and when that's reached a decent amount I'll look forwards to touring there. My current planned budget includes an annual ferry allowance. I also have a lot of research done into the bewildering variety of 'over 3.5t' road tolls across Europe though I'm unsure of how much to budget for this... I'm also mindful of likely higher insurance premiums as the size (and value) of my target van has increased, but I've yet to re-do the quotes. I'll use a fair bit more gas too.
My planned winter (March probably, November to February there's too little daylight) tours in Scandinavia are, so far, to some specific places in Finland (maybe Sweden too): http://www.wildtaiga.fi/en for nature observation/photography (and maybe the odd sauna & birch thrashing!! haha!). Poland (and Romania) for bison re-wilding projects and Abruzzo for wolves (bears in Abruzzo in late spring/summer), high Atlas in Morocco. These projects involve daytime temperatures of zero to -5 and nighttime temps down to -20 and then warming up into spring. I have my eye on some boot-heaters! So far I have journalistic projects planned over 5 years in the field of nature conservation and tourism & environmental education. Then there's Turkey but I've yet to research that....
I've yet to win the Lotto but not having children (or alimony payments!) whilst tragic (not really, haha!) means that I'm now looking forwards to spending my own inheritance and life savings - all of it, before I'm too geriatric to care. Until the motorhome touring plan germinated I was planning on buying a small farm in Italy... now, as it turns out, some Italian friends of mine who live on an orange & olive farm in Sicily have told me I'm welcome to come and stay for as long as I wish, I think they want me to teach their children English.
Now I've drunk all the wine! Happy Motorhoming for 2015 Funsters! I hope to be amongst you by the summer :)
Bertie Bassett
2,743
8,702
since 1988
Hope you've had a good New Year, have you seen the finnature site..............excellent for viewing/photography of birds, bears and wolves. It has been recommended to us for Owl Watching trips...........not cheap but once in a lifetime. Away from the coast in Finland expect March temps down to - 35 and below on occasion so heated boots are a great idea!
http://finnature.com/
Jun 10, 2010
8,524
20,241
Shrewsbury (sometimes)
N&B Clou Liner MAN
Mercs make a good nicely finished vehicle, but IMHO they are not the quality that they used to be. It is noticable how few of the quality GERMAN mh's are on a MB chassis.
The downside of the twin wheel MB is that they can be very very bouncy. I believe they are better with air suspension though.
Yes I do find Fiat/Alkos hard
It depends what your priorities are but I would give later Iveco based vehicles serious consideration - that is as long as you can find the layout you want.
19,377
30,375
You need to remember that when you lock the rear diff you loose a lot of your steering so it needs unlocking ASAP.
Peter A Forbes
270
184
Mercedes 614D
Interesting that our 614D had factory-fitted 'soft suspension' which is parabolic springs instead of the standard leaf springs, with anti-roll bars and special shock absorbers.
Peter
