Truma water heater (2 Viewers)
Aug 18, 2014
23,795
133,793
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
My water heater appears to have stopped heating. When I turn it on the green light comes on & then after say 20 seconds goes out. doesn't turn red just goes out. I spoke to chap where I bought it & he suggested the solenoid valve ,which I had also seen references to online ,but I have been unable to find it.
I am told it should be visible but I cannot find it anywhere. Pipe does go behind fridge & I wondered if it is there? I have tried banging the pipe as suggested in case it is inside boiler casing & this appears to have done something because now when you turn on, the light goes green but on the pcb the light is flashing with like a piezo spark clicking noise but unfortunately it is still not lighting.
Boiler is a Truma 10 litre type: BO model B103. Yes it is original , 1989.:LOL:
gus-lopez
Aug 18, 2014
23,795
133,793
Lorca,Murcia,Spain
Transit PVC
Unfortunately it never came with one ; nor have I a switch on the Kitchen window above & slightly to the side which is another thing that is possible to lock it out .
mike mcglynn
Jan 6, 2008
2,700
32,552
St. Helens MERSEYSIDE
Autosleeper Warwick XL
A long time now
Ok ,Gus check out gas supply from bottle sometimes the regulator needs to be reset some have a little yellow button just push it in ,worth a try.
gus-lopez
Aug 18, 2014
23,795
133,793
Lorca,Murcia,Spain
Transit PVC
I have been wondering about that as when it stopped working in the UK I didn't really have time to investigate. Shortly after it stopped working I then changed from spanish butane to UK propane & regulators as well & the propane one is adjustable. I have been wondering whether the pressure is too high , although I have tried it lower . perhaps I'll have to try it with a fixed butane regulator to see whether that is the problem now.
