Truma warm air heating (1 Viewer)
LPB
Aug 19, 2015
120
63
Crawley
Hymer B584
I'm a newbie
We have a Hymer with Truma wam air heating.
How powerful is the fan supposed to be? Ours is pretty pathetic.
Thanks,
Lloyd
BwB
917
1,170
Suffolk UK
Resting b'twix vans
Since 1990
Should have a good blow. Check the air input isn't clogged with fluff and lint :)
Munchie
8,921
12,581
Camping Les Vigeres
Font Vendôme
Since 2004
Very! Ours has us sweating in 5 minutes!
Starts slow then winds up like a jet taking off!
7 metre van red hot in 5 mins.
Margaritaman
270
395
East Yorkshire
Low Profile C Class
since 2008
Have a Truma 6E that I run on 240v most of the time. On my system the fan speed is regulated by two things (and in this order).
Firstly the temperature of the hot water and the heat exchanger.
Secondly the difference in temperature inside the van and the temperature setting the unit is set to.
If you are heating your van from cold and your boiler water is cold try heating the water only ( on gas, electric or gas+electric) for five mins.
Then switch over to hot water + heating and turn the thermostat up to full. You should then hear the fan start to gain speed for a while then die down to a background speed.
Glandwr
Banned
Jul 10, 2014
1,057
3,301
the Berwyn Mountains
Hymer S740
since 2009
Ours has a gate value on all outputs. With all open you should feel a flow of hot air with your figures if you hold them across any outlet.
Dick
Mr B
990
1,889
Yorkshire
Rapido 7065ff Design Edit
Since 2015.......
Ours is the same.
Have any of flexi pipes come away from outlet ports. One of ours had came off, so the draw above it got red hot... Soon rectified though.
Burns your foot now when your near the kitchen area :)
Wickolad
490
542
Wickersley
Newbie to MH, 20yrs+ Caravanning.
The Truma heaters have a butterfly valve which is adjustable at the rear of the heater unit, there is a small lever which operates the butterfly valve, this adjusts the priority of % airflow to the front or rear of the habitation area. If the butterfly valve is set prodominently to the front, you would get stronger airflow to the front and very little to the rear and vide versa. Check the heater outlet vents front and rear when fan turned on full see which has highest airflow, then adjust the butterfly flap valve at the rear of the fire to suit your needs.
As previously mentioned, check that the flu pipes are all connected and that one has not become disconnected which would interrupt airflow. This should solve the problem.
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
I too would suspect that the ducting pipes have come adrift from the outlet nozzles on the Truma. It's not uncommon and it is good practice to check them at least once a year. They are a push fit that clicks into place. Make sure you do it when the Truma is cold as it's easy to burn yourself on the nozzles.
Allanm
5,431
9,192
Cotes d'armor, France
Burstner Harmony TI 736 G
Since 1987
Ours is the same on a Truma 4e. You can't put your hands in front of the outlets for more than a second without them glowing red!
Jul 5, 2013
11,731
13,707
Since 2013
Are you using it only on 240V? In that case it will not have much power, because the heating element is only 1800W. Put it onto gas, which has about 3 times the power, or gas and electric, turn the thermostat right up and it should start blowing very well. But it will take a couple of minutes to fire up and bring the fan up to full speed. Once it has reached its temperature the electric setting can then keep it at the right temperature except in really cold weather.
movan
21,492
120,753
Moving around
Burstner
since07
Crumbs, something else for me to learn how to do.. My brain is becoming addled this year with maintenance issues. :)
LPB
LPB
Aug 19, 2015
120
63
Crawley
Hymer B584
I'm a newbie
Thanks everyone, I cranked up the thermostat and it was much better.
I have a separate switch for 240 water. Its a Trumatic C so gas only,
Thanks,
Lloyd
sdc77
3,244
4,550
Weardale, Co Durham
since 2011
Last time Truma saw our boiler they secured each of those outlet pipes using that silver tape stuff.
