Truma heating question (1 Viewer)
Lindylooj
189
81
Weymouth, Dorset
Autotrail
Newbie from Oct 2011
Sorry everyone, have read booklet for heating still no comprendez. We managed to get the heating working via the gas, but how do you get it to heat using mains electricity? Didnt seem to want to work for some reason (reason probably us not doing something right) but any ideas please. :Sad:
43,330
49,446
does it actually have the ability to work on leccy...some do, some don't
if it does it may be the heating element has blown or even a fuse/breaker has tripped
Lindylooj
Lindylooj
189
81
Weymouth, Dorset
Autotrail
Maybe the element then, as definately should work off leccy and trip switches OK. Thanks
1,710
617
The world
Small car
is it a mains 240volt heater?? SOME ARE JUST GAS :thumb:
SPUD'N'T
190
4,318
YORK ENGLAND
COACHBUILT (LOW PROFILE)
since 2008
are you waiting long enough for it to warm up on leccy ? ... ours warms up fast on gas but seems to take ages on hook up, once up to temp though it's fine.
SilverF1
109
68
Worcestershire
Low Profile
7 years and upwards
I don't know which model of Truma heater unit you have but this page on the the Truma website may be of help:-
Link Removed
Lindylooj
Lindylooj
189
81
Weymouth, Dorset
Autotrail
Thank you both. We turn the left hand dial on top of heater up, is that all we have to do apart from making sure we are hooked up and switched to 240 of course. The gas was no problem. We are off for our first rally this weekend so would like to have it working of leccy and not the gas.
S
stagman
Is there a switched fused spur that is off , it may be in one of your cuboards .
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
It may depend on which model heater you have. If it is a C3004 / C6002 with electric option, then the electricity only heats water, not blown air. Someone else asked the same question recently, maybe on another forum, and I checked my instructions.
Lindylooj
Lindylooj
189
81
Weymouth, Dorset
Autotrail
Just checked we have the S3002/S5002 model. Note the booklet says additional 230v electric heating optional so not sure how I find out if we have it or not!
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
if this is similar to the one fitted in my dads motorhome there is a separate dial and switch for the mains side.
it looks like a thermostat with a small switch under the dial with 500watt 1000 watt and 2000 watt settings.
3,994
6,254
Rochester
Auto-Trail Mohawk
16 fun filled years
I'm wiv Andy on this one, my Bessie Truma heater does gas or leccy, and there is a seperate dial for leccy as Andy has shown.:thumb:
JeanLuc
3,304
2,199
Warwickshire
Just had a look at the instructions in the Truma download section of their website. The standard S3002/5002 are gas-only heaters. The Ultraheat was an optional extra that could be fitted to them. Here is the introduction to the instructions.
Short description
Truma Ultraheat is an additional 230 V electric heater for the LPG heater models Trumatic S 3002 (P), Trumatic S 5002 and Truma S 55 T.
Heater operation is basically possible with gas only, electricity only or simultaneously with electricity and gas.
When using simultaneously the electrical unit will switch itself off before overheating occurs as a result of the stronger gas burner.
If you have it, you will see a dial as indicated in Andy's post - if not, I suggest you don't have it.
WynandJean
6,670
3,303
West Midlands
Bailey Autograph 682
Since 2010
We had the same problem with ours. Was trying to get it to run heating on electric but found that while it heats water on gas or electric will only run heating on gas, therefore bought halogen electric fire.
I have enquired about a collar which is available to fit on the boiler but have not had a satisfactory reply to this.
Wyn
Lindylooj
Lindylooj
189
81
Weymouth, Dorset
Autotrail
Absolutely spot on, once we found this and turned it on, hey presto got the heating to work so thank you and everyone else that replied. i love this place there is always an answer without making you feel a complete plonker. Had a good weekend, nothing major went wrong apart from not having right adaptor for water tap, but other kind motorhomers helped with that, and we blew the electrics. took a day to tune in tele but all good fun and we had a great weekend.:Smile: Couldnt reply before as we bought a dongle thing for computer but think it had to circle earth 60 times before we even got a signal
