Trtuma shower question.
Discussion in 'Motorhome Chat' started by Bushtrekker, May 25, 2012.
  1. Bushtrekker
    Bushtrekker Read Only Funster
    Jan 4, 2012
    253
    120
    Cannock, Staffs
    The previous owner removed the shower from the camper, but I want to put a trigger shower in and wondered if anyone could suggest where I might find a photograph of what should be there?
  2. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,602
    Ilfracombe, Devon
    sounds to me like he had leak problems why else would it be removed. Anyway good luck with the replacement.
  3. Bushtrekker
    Jan 4, 2012
    253
    120
    Cannock, Staffs
    Shower
    He told me that he had removed the shower from his rerplacement Hymer as well, saying thath they were running out of hot water. The heater works perfectly and consistently, so I can only assume that they were trying to use it as they would at home. Welcome back by the way, we were down your way last week on the way home and stopped for a pasty at Hartland Quay.
  4. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,376
    9,823
  5. TheBig1
    Nov 27, 2011
    7,376
    9,823
  6. Heyupluv
    Heyupluv Read Only Funster
    Oct 7, 2008
    3,860
    1,583
    France,
  7. Bushtrekker
    Jan 4, 2012
    253
    120
    Cannock, Staffs
    I've got the head.
    I can't see where he's disconnected it from and his phone is on answerphone. All I can see is the knob which changes from hot to cold water and two holes in the top of the unit, but no obvious point from which it's been disconnected underneath and there isn't a lot of room under there.
  8. Heyupluv
    Oct 7, 2008
    3,860
    1,583
    France,
    Bushtrekker I have taken this photo off the internet of a Hymer tramp shower does it look the same as yours....
    If not, could you put some photo's so we can see what you are talking about and then we may be able to help you
    Mel
  9. Bushtrekker
    Jan 4, 2012
    253
    120
    Cannock, Staffs
    That looks like a new Hymer Tramp
    This is what my shower room looks like, showing the holes where it looks as though there should be a tap, but I can't see any blocked off pipes.
  10. Heyupluv
    Oct 7, 2008
    3,860
    1,583
    France,
    It looks like the silly man has taken the complete connection out, how mad is that....,can you get to the pipes from the underneath .....what year is the Hymer.
    Mel
  11. Bushtrekker
    Jan 4, 2012
    253
    120
    Cannock, Staffs
    I thought that.
    It's a 1988 Hymer and I seem to remember seeing on an old catalogue which I can't re-locate that the shower head sits in the unit next to where the sink comes down.
    When I reached underneath I assumed that he had just blanked a pipe off, but as you say it looks as though the lot is missing. The shower room is immaculate and the tray free of cracks, so I'm reluctant to remove panels.
    John
  12. Heyupluv
    Oct 7, 2008
    3,860
    1,583
    France,
    John, if you can to the pipes from underneath...that's fine, don't remove any panels... what happens when you turn the control knob from hot to cold
  13. Bushtrekker
    Jan 4, 2012
    253
    120
    Cannock, Staffs
    I haven't tried turning it.
    There is an identical one in the kitchen area, so I'm fairly sure that it controls the water from the boiler.
  14. Heyupluv
    Oct 7, 2008
    3,860
    1,583
    France,
    it looks like you will have to buy the complete unit with pipe...tap with electric fittings something like this....(this is just a example)...but you need the with micro switch...then fit to existing hole
    http://www.olearymotorhomes.co.uk/cara-shower-kit-2-978-p.asp
  15. Heyupluv
    Oct 7, 2008
    3,860
    1,583
    France,
  16. Heyupluv
    Oct 7, 2008
    3,860
    1,583
    France,
  17. Heyupluv
    Oct 7, 2008
    3,860
    1,583
    France,
    Give Peter a call.. PM..on here MHFun (John CrossMotorhomes) he is a Fun Member, he will help you if he can most likely tell you to contact his service manager for advice...he will know what you require for your Hymer tramp
    Mel
  18. Bushtrekker
    Jan 4, 2012
    253
    120
    Cannock, Staffs
    Thanks and more pictures.
    Cheers Mel, I'll PM Peter later as he has already given me their number to establish what the fitting is for my awning. I've managed to establish this morning how their colour code works and at which point the water is mixed, but still can't work out how the hell he got to it. although it looks as though the mirror can be removed for access. Here are some pictures taken on my mobile this morning.
    John
