Trike towing
Discussion in 'The Beginner' started by The Bold Eagle, Aug 23, 2014.
  1. The Bold Eagle
    The Bold Eagle Funster
    Aug 17, 2014
    18
    Does anyone out there tow a trike on the back of their motorhome ? Any help or advice or tips would be greatly appreciated.
  2. old-mo
    old-mo Funster Extra Special Life Member
    Oct 16, 2008
    12,762
    39,080
    If you tow one it will have to be on a trailer...
    Even though it will be well under the 750kl..
    It has brakes fitted, and if it has any that are on the road they must work in tandem with your M.Home...:(
    Front wheel off the ground = Illegal. as the back wheels will have brakes which must work when your brakes on the M.home are activated.. :(
    Sorry no way round the law... (As far as I know)
  3. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,703
    17,323
    YO11 2BD
    Other than to ignore the law.....certainly not advisable but many do it.
  4. pappajohn
    Aug 26, 2007
    29,703
    17,323
    YO11 2BD
    When the northern motorhome show was at york a few years ago i saw a reliant robin/regal being towed 'front wheel up' into the show ground.
  5. vwalan
    vwalan Funster
    Sep 23, 2008
    7,601
    3,855
    roche cornwall
    you can easily sort out an electric solenoid to pull the foot brake . using the brake lights and a relay. might need a bracket made to carry the bits .
  6. old-mo
    Oct 16, 2008
    12,762
    39,080
    I think the police would turn a blind eye, But if you have an accident, they would be down on you like a ton of bricks... plus the insurance implications..
    I always put mine in a trailer..
  7. scally
    scally Funster
    Aug 15, 2010
    619
    2,279
    essex and lincolnshire
    I tow mine on a trailer but two friends of mine tow them on the ground one with all three wheel on a bar and the other with front wheel in a pocket bolted to van.. as far as I understand if three wheels on road then comes under the steerable front wheel four wheel trailer laws if two wheels on road the normal trailer rules apply. Its a very grey area and none of the authorities I have approached seem to know for certain.
    • Like Like x 1
  8. pappajohn
    Aug 26, 2007
    29,703
    17,323
    YO11 2BD
    Regardless of how many wheels are on the road it needs operational brakes.
    The law requires any braked wheels need to operate regardless of weight.
  9. Peter & Elaine
    Peter & Elaine Funster
    Aug 30, 2012
    3,972
    6,468
    Roobarb land
    At the end the day it's your choice I have looked into this in detail and as they say on here if it's fitted with brakes the brakes must work
    I tow a rewaco hs4 with the front wheel of ground on a tow frame that locks the steering and allowes the articulation on the tow ball no brakes working
    If I get pulled by plod so be it then I will come up with something else
    Plus most of the plod are proberbly not clued up any way and it would end being vosa that nailed me
    So till I get pulled bugger em for now
    I will post some pics of frame when I get home
    • Like Like x 2
  10. Peter & Elaine
    Aug 30, 2012
    3,972
    6,468
    Roobarb land
  11. The Bold Eagle
    Aug 17, 2014
    18
    Thanks to all. Not as straight forward as I thought. Looks like it is going to be a trailer. Glad I asked. Much appreciated.
  12. Peter & Elaine
    Aug 30, 2012
    3,972
    6,468
    Roobarb land
    The only reason i don't use a trailer is it takes up too much room on site (n)
    Some site have spaces that are small and not enough room to have a van trike and trailer on the allocated pitch
  13. old-mo
    Oct 16, 2008
    12,762
    39,080
    A lot of sites have enough room for a car and caravan, like wise with a motor home and small trailer..
    I used to put the trike as with a car in the trailer on the same plot if tight for room.. (y)
  14. vwalan
    vwalan Funster
    Sep 23, 2008
    7,601
    3,855
    roche cornwall
    a simple t shaped trailer can be made that should almost disapear under the m,home when on a site . just poke the front end under and drive ,reverse over it .
  15. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,602
    Ilfracombe, Devon
    drop the wheels off and shove it right under the motorhome
    • Like Like x 1
  16. vwalan
    vwalan Funster
    Sep 23, 2008
    7,601
    3,855
    roche cornwall
    thats a good idea .
    simple u channel as the T frame . need some triangulation supports but not much.
    could be made in minutes . mind new trailer pain to do . better build an old one . ha ha . nod nod .
  17. movan
    movan Funster Life Member
    Dec 2, 2009
    13,229
    23,755
    Moving around
    http://www.motorhomefun.co.uk/forum/media/
    I was told when I was towing mine it had to be on a trailer because it was an automatic... Don't know if that of interest or help. Sorry photo won't download but above is the link.
    • Like Like x 1
  18. vwalan
    vwalan Funster
    Sep 23, 2008
    7,601
    3,855
    roche cornwall
    something else to think about . not good towing most auto,s .
    should have bought a manual change . never mind .
    but looks good fun .
  19. Jim et Lou
    Jim et Lou Read Only Funster
    Oct 12, 2013
    216
    160
    Sheffield
    I tow a Trike and think the same as Pete. Just got back from the Lakes, no incidents
  20. Peter & Elaine
    Aug 30, 2012
    3,972
    6,468
    Roobarb land
    What make is it joy it looks good
    Automatics can not normaly be towed as it damages gearbox and torque converter
    • Like Like x 1
Similar Threads
  1. sewinlynne2
    11
    480
