Tow bar height/bike rack height (1 Viewer)
Ridgeway
3,657
6,152
Lausanne
NiBi Arto 85E
Since 2012
In my bid to find a way to carry 6 bikes without having the ordeal of towing a trailer I think the best solution will be a Thule type tow bar mounted bike rack with the usual Thule Omni Bike rack hard fixed to the rear wall. The Omni rack is already on and is fortunately mounted very high due to the toilet cassette access door being on this rear wall. I have pricing and specs for the chassis extensions, tow bar and electrics plus the bike rack that I will mount on it however I can see now that the space between these 2 racks will not be large and may only cope with children's bikes which is fine for today.
I was wondering if anyone has any idea on what height the tow bar would be at and also if anyone has done the same and what height does the bike rack sit at ?
Here's some pics of the rear of the MH with the existing Omni rack already on,
[/IMG]
[/IMG]
I have checked with the tow bar installer to see what height they believe it will be at and they say the top of the tow bar should be approx 17-19" or just below the number plate, this is already slightly vague (not their fault as they haven't seen the MH) plus I have to guess where the rack will fit relative to this and ideally I'd select one that sits particularly low in order to use the space efficiently. Any ideas on what rack sit low ???
Was looking at a Link Removed
Any thoughts/ideas ?
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Be aware going to low may hinder you on ferry ramps, wrecking the bikes or carrier or both
Geo
Ridgeway
Ridgeway
3,657
6,152
Lausanne
NiBi Arto 85E
Since 2012
Geo
Hummm, that's a good point.
Jul 24, 2009
4,330
104,505
South Yorkshire
Since 1999
I believe that towbars are a nominal 400mm or 16" in English money in height to the centre of the ball.
Ridgeway
Ridgeway
3,657
6,152
Lausanne
NiBi Arto 85E
Since 2012
Thanks, that's useful to know. An inch here or there will make all the difference.
TheBig1
17,630
43,279
the bar I recently had fitted gives a choice of 16" or 18" from ground to centre of the ball, as these are standard for uk made trailers
GJH
29,450
38,827
None, now sold
2006 to 2022
I can't tell from the photos what overhang you have behind the rear wheels but with any load on the rear you have to be careful not to exceed the rear axle weight - and the longer the overhang the more that is magnified. 6 bikes could easily exceed 100 kilos together.
