Tom Tom sat nav upgrade to camper software (8 Viewers)
Peter S
86
15
Towcester
A class Concorde liner 89
Since 2011
I'm sure this has been covered many times before however:
We have a World Tom Tom which goes with us everywhere and is brilliant. With the impending arrival of our concorde, yesterday I upgraded the software to the camper version.
This morning I have used the MyDrive system to plan a route having put in the size of the vehicle. I deliberately picked a destination in North Devon where I would definately have a big problem taking a 9mtr motorhome to see if it warned me that the route would not be passable. The system quite happily recommended an impossible route. I then changed the size of the vehicle up to a full sized artic to see if it restricted the route - again, it just let me go ahead and plan it without any restrictions.
The software upgrade cost was £74.95 and is as much use as a chocolate fireguard.
Feb 9, 2008
8,953
18,710
Corby, Northants
Coach Built
Make sure you select the right vehicle in the vehicle types section in settings. It's possible you are still in car mode and not campervan mode.
Peter S
Peter S
86
15
Towcester
Since 2011
Nope selected the motorhome icon. If it is set to car, you cannot input the size of the vehicle.
19,377
30,376
If the road sizing information is not on the map data it will just send you down unsuitable roads, it looks like the destination you picked does not have the relevant information on the maps.
Is there a passable route with a detour that it should have recommended or was it an impossible task?
Peter S
Peter S
86
15
Towcester
Since 2011
Hi Martin, its a very tight route even with a detour. My concern is that I know where the road narrows coming out of a particular village it says its impassable for caravans and trucks on an official road sign. So if it cannot deal with that situation I just cannot see how I can trust it with anything. Just makes me wonder if the road suitability function is only limited to major routes and is therefore pretty useless.
19,377
30,376
With the impending arrival of our concorde, The system quite happily recommended an impossible route. I then changed the size of the vehicle up to a full sized artic to see if it restricted the route - again, it just let me go ahead and plan it without any restrictions.
So I will do you a favour and take the Concorde off your hands as you obviously wont be able to make use of it now(y)
19,377
30,376
Hi Peter
I dont think its good to ever trust these things too much, I have and I know where it has taken us:LOL:
If you want to give me the two post codes I will try the route in my CoPilot which again is supposed to route on suitable routes.
Peter S
Peter S
86
15
Towcester
Since 2011
Hi Peter
Hi Martin, I agree - I was just having a Sunday morning poke about. The route was:
Towcester
Croyde
Putsborough Sands.
The road from Croyde to Putsborough, even with a detour via Georgeham is incredibly tight - its like driving into an ever narrowing funnel!. I have driven it several times. The rest of the route is absolutely fine. Thanks, Pete
weebill
66
86
aberdeen
Coach built
since 2006
Hi Peter
I purchased a new TomTom 6000 with a view to installing the camper software I had used for a few years on my TomTom Live Camper edition which had a cracked screen.
It seems TomTom do not allow this as the software running on the 6000 cannot accept vehicle dimensions.
After a few attempts with TomTom to find a solution
I gave up and reverted to my original TomTom, had it repaired and updated the software. All working fine and in 20,000 miles has never led me astray.
19,377
30,376
If I set the route in CoPilot for a car it gives two option one going around the coast to Croyde and then Putsborough and the other through/around Georgeham but if I change the spec to caravan it does not give the the Georgeham option only the one around the coast and Croyde.
Peter S
Peter S
86
15
Towcester
Since 2011
Interesting. Don't try that route in your Flair would be my advice :D Thanks for trying it out, Pete
Apr 11, 2015
5,421
55,313
hull
Laika Ecovip 300
We have 3 tom toms one each and one for the bike, none of them are compatible with the update, which Tomtom do you have?
DJA
Mar 5, 2011
661
1,014
A
Since 2008
Hi Peter
I have just tried the route on the latest Garmin camper and it recommends a route without any comment about access problems. However when I got it to simulate the route from the centre of Croyde when it got to the junction towards the final destination, which is by a garage, it then it warned me that Motorhome/Caravan Access was unknown for the road ahead but still continued to travel along the route. So it would seem that the first I would know there is a problem is when i get to that junction. Is it the same on the Tomtom?
Doug
DJA
Mar 5, 2011
661
1,014
A
Since 2008
Hi Scotzsue
The tomtom website list the units the map is suitable for. I know it will work on a Tomtom 120 and that it will recommend different routes for Cars and Motorhomes depending on the roads involved. I don't know when in your journey it will warn you the route ahead is likely to be a problem.
Gellyneck
9,246
18,338
More than toes wet now!
@Peter S
Using Garmin Basecamp with a motorhome profile this returns a route from Towcester via Mullacot \ Pickwell \ Putsburgh bypassing Georgeham and Croyde.
Been on that route with a c42' car \ caravan up to Mortehoe Station Road (heading to Damage Barton) and it was fine. Don't know what it's like thereafter to Putsburgh but Google shows it as "reasonably" straight but narrow (a couple of tight bends though).
I've attached the route detail from Mullacot to Putsburgh below.
Is it OK or a "life in your hands" option?:eek: Be interested to know.
  • Mullacot - Putsburgh.pdf
Peter S
Peter S
86
15
Towcester
Since 2011
@Peter S
Thanks for that.
The road from Georgeham all the way to Putsburgh is single track. Something comes the other way, even with passing places you are in deep do - do.
Interesting how the garmin takes a different route though.
Peter S
Peter S
86
15
Towcester
Since 2011
Demand your money back.......good luck with that. :whistle:
Going to try tomorrow - see little point in having it if it does not do the job.
I have tried planning another route local to me to see if it routed me around another very tight spot and it does'nt so its utterly pointless.
Peter S
Peter S
86
15
Towcester
Since 2011
Hi Peter
Doug
Hi Doug, I have not tried the simulation. However, where your garmin has done has stopped you is exactly where the problem starts, right near that garage so at least it did that. Thanks, Pete
Gellyneck
9,246
18,338
Thanks for that.
Agreed, it's all single track roads down to Putsburgh Beach. Think BaseCamp has picked the best of a "difficult" bunch though as the others all appear to be more twisty and it keeps you out of the village of Georgeham.
Looks like sat nav may work on the principle if that's the only way well that's it rather than saying "not a hope in he**"!:eek:
DJA
Mar 5, 2011
661
1,014
A
Since 2008
Hi Peter S
I have tried the simulation on a Tomtom and it does not issue a warning.
I would say that I have had problems with the Garmins routing, probably more so than a Tomtom. For example directing into a deadend alleyway behind some houses going to the Moffat Campsite or directing into a layby, where access is denied, and then asking you to exit the layby turning right across a four lane road. The latter ignores the fact you can drive 70yrds further and use a roundabout to take you in the direction you want.
Others have advocated that they have a system that never lets them down such as Here maps, In this case when asked to say what route that would offer the resulting First Choice recommendation was a route I would only take our Toyota Aygo along if all other roads were closed.
Regretably there does not appear to be a perfect system and when problems occur it varies from make to make. I find that generally these units are a boon making life a lot easier but accept that very very occassionally I may have to make my own decisions if I am not happy with the sugestions they are making.
Doug
Forestboy
5,023
8,338
Forest of Dean
A Class Hymer B694 tag
We've tried a lot of so called truck satnavs at one time or another especially when we had RVs and honestly never found one that was any good probably the worst being the most expensive Snooper.
Although we no longer have RVs our Hymer is a 5 tonne tag and 7.5 mts so not massive but still largish. We now use Copilot set on RV and common sense, the days of blindly following sat navs are behind us and we always have maps on board.
Personally of all the sat navs we tried Garmin was way better than any other but CoPilot is better than them all although I'm struggling with the new update, why can't they leave it alone.:swear2:
DJA
Mar 5, 2011
661
1,014
A
Since 2008
Hi Forestboy
I downloaded Copilot and understand your comment re the latset update.
If you use Copilot in RV mode and seek a route between Borough Green and Longfield Centre it takes you via Ash which involves narrow country roads with passing places in one section. Tomtom and Garmin take you via the A227 and B260 which is the best way to go with an RV although the Garmin ignores the B260 turning and takes you through a shopping area before returning to the turning. Also on Copilot if you change the destination to Longfield Hill it goes via the A227 and B260 but ignores the B260 turning and takes you via Mellicker Lane which is a narrow single track bit of road before joining the B260.
As I said they are all likely to have the odd problem and this is concerning when you are in an area you don't know , which is what you use them for. When you can see some of the silly things in areas you do know it does little to give you confidence.
Doug
Jul 5, 2013
11,731
13,711
Hi Forestboy
Doug
Well I now know what part of the country you line in!
Reactions: DJA
Peter S
Peter S
86
15
Towcester
Since 2011
Thanks for all the comments and feedback
