toilet cassette door (2 Viewers)
freelanderuk
1,018
534
Saltfleet/Lincolnshire
c class
We are on a site for the weekend and just tried to get the toilet cassette out of the locker but can not get the lock open , tried wd40 and oil but not having it, would a screw driver in the lock open it , have some new lock barrels at home, any ideas please
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
The lock barrel outer is located by a flat on one side, if you force it with a screwdriver you will lose the barrel location register unless you re fibreglass it. I suspect the pins in the lock are seized wd40 may do it or even vinegar to dissolve the rust make a dam under the lock fill and leave for 24hrs then try. I hope you get it sorted soon or you will be in deep do do, hee hee
4,924
11,290
Flintshire
Low profile
since 2010
I guess you have tried pushing inward on the door to take the pressure off the locking arm, then turning the key
Dec 6, 2011
11,593
25,426
South Wales
Coach built Adria
i actually busted one of these locks unintentionally because it was stiff. it sheared the rear peg and plastic sleeve on the back of the lock.
had to use a screw driver in the barrel hole to open the lock.
got a complete replacement for about ÂŁ15 no issues.
as long as you dont damage the door, or frame you should be ok.
but as has been suggested try all else first. good luck:thumb:
mick noe
Apr 14, 2009
638
539
near Boston Lincolnshire
low line
if wd does not do the job I would not force it with screwdriver etc. for fear of damaging the door or frame. Best bet is to drill centre of barrel out, start with small bit then run big one through:thumb:
Apr 19, 2008
1,942
2,921
Kent coast Hythe
Rapido fiat based
brought first van 16 yrs ago
try entering paperclip into key hole to liftbarrel pins aided by small electrical screwdriver. some times key wears away and does not lift enought to allow barrel to turn. this takes some practice but does open
Peter JohnsCross MH
Jan 5, 2008
9,617
6,194
East Sussex
Autotrail
If you have no joy before you get drastic give Glenn or Ian a call on 01-580-881288 and pick their brains:thumb:
Peter
Jan 4, 2012
2,242
2,023
somerset
Fiat Ducato
A few years now
Knock the hinge pins out.
Use a 2mm blunt pin and tap on the small side of the pins
Repair the lock ,test, refit pins :thumb:
F
freelanderuk
1,018
534
c class
All sorted, I pushed the hinge pins out and took the door off, stripped the lock down and found the cause,
The o ring that seals the push Button had perished allowing water on to the locking mechanism causing it to crud up.
Cleaned greased and back together, just a small o ring to get
Thanks for all replys
WynandJean
6,670
3,303
West Midlands
Bailey Autograph 682
Yes, often we see a thread posted and wonder what the outcome was. Whatever the solution is (or even the fact that there wasn't one) is likely to help others.
Wyn
