To weld or not to weld (1 Viewer)
Nov 18, 2011
11,862
43,044
Planet Earth
A van
Over 25 year's
To weld or not to weld that is the question.
I have a crack in my exaus system.
Nothing to serious but old stell is notoriously difficult to weld.
Am I being a tight git should I just splash out on a new one at £193
Bill
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
with a mig welder it should be ok.
i would certainly have a go.
might put a bit of extra support on it or patch as well.
i made new ends for my silencer 3 years ago still working .
Lenny HB
53,448
150,060
On the coast in West Sussex
Hymer B678 DL
Once exhausts start going normally faulse economy to repair them. If you repair it another part of it is bound to let you down at the most inconvient time.
Wildbill
Nov 18, 2011
11,862
43,044
Planet Earth
A van
Over 25 year's
I have all thre stick mig tig I do like tig. But getting a good clean prep with old stell might be a problem.
Bill
Wildbill
Nov 18, 2011
11,862
43,044
Planet Earth
A van
Over 25 year's
It's just a crack next to a weld stress crak by the looks of it
Bill
Enword
1,900
7,999
Devon
Coach Built
Race van conversion for years
If there is no corrosion / rot & only a stress crack shouldn't be a problem, go for it.
Wildbill
Nov 18, 2011
11,862
43,044
Planet Earth
A van
Over 25 year's
A pick thinking new on
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
slip a bit of tube over it and strengthen it . a bit of ex pipe cut then slipped over and welded should be ideal.
i certainly dont just swap mine when 20mins of welding will fix it .
i use mig at home but do take inverter welder away in the truck .
inverter better than normal stick but mig is better .
i cheap skated and bought a cheap inverter welder in spain several years ago . shame it never came with tig .
mind i did weld the leaf springs on my trailer with it one year in morocco. got me home .
Wildbill
Nov 18, 2011
11,862
43,044
Planet Earth
A van
Over 25 year's
Yes that could be a option will wip it off and give it a go nothing to lose as I can't get another one till Wednesday or Thursday
Bill
Jan 28, 2008
10,117
18,382
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
Ive found patching boxes to be a waste of time as they rot from the inside as fast as you patch one place it goes in another pipes can be worth doing and cracks on flanges
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
just recover them . wrap a sheet of steel around the silencer,then make shaped end caps welding to new steel all the way . fit slightly over size end pipes so you can slip in the original . job done . cost almost nothing if you do it yourself .
sometimes i consider covering new silencers with galvanized steel from new .
mind truck silencers do take weld repairs much better than car a van silencers . heavier steel used .
2657
Wrap a baked bean tin round it, seal with gun gum, tighten up with wire......proper job:rofl:
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
i did that just before leaving spain last week. waiting for a dry day and i shall weld it up better.
mind i used a carrot tin ha ha .
Wildbill
Nov 18, 2011
11,862
43,044
Planet Earth
A van
Over 25 year's
Now that I have dug out the welding kit the mirror bracket that's broken and Ben meaning to make a new one started fabrication of a new one
Sum pick
Bill
I have put original for comparison and scale
Bill
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
It would with the baked beeeeeeeean tin Bill
It only has to be semi gas tight and how its made that way or repaired aint an issue ;)
Wildbill
Nov 18, 2011
11,862
43,044
Planet Earth
A van
Over 25 year's
Thanks @Geo I didn't know that any way done now
Just got the mirror bracket to finish when I get home tomorrow then find a mot station to do the mot
Hopefully thay can set up the head lights
Bill
