To fit a curtain at front of MH without curtain rail. (1 Viewer)
etap
256
228
Somerset
Chausson Flash 610
3 years
Hi, because there is not enough space above cab on the wood facia to fit a curtain rail, have been thinking of other ways to do this i.e. Snap hooks/ magnets, neither of these is strong enough so was wondering how others might do this, any ideas would be appreciated.
Etap
Sep 5, 2012
2,109
42,225
Scotland
East Neuk Fifer
since 2012
We use and an extendable shower curtain pole with eyelet curtains, would that work in your set up:)
Cal54
3,806
62,035
Southport, UK
Leisuredrive Renoir
Since 1996
Not sure exactly were you are meaning - is it the windscreen or are you wanting to separate the cab from the rest of the van? If the latter, my neighbour has used Velcro and a lightweight fleece blanket that she puts up at night. She reckons it makes a great difference and definitely keeps the van warmer and free from drafts. Very little weight and very easy to launder.
Mar 11, 2014
934
1,331
Lincs
PVC
Since 2010
Is there enough space to fit this type of curtain rail?
http://www.terrysfabrics.co.uk/prod/curtain-track/swish-furniglyde-track/
I've got one ready to fit to section off the cab in my van - I just need to get around to it.
It can be face fixed instead of ceiling fixed - you just need to order the different button hooks to go with it.
I've already ceiling fixed one to separate the sleeping area.
etap
etap
256
228
Somerset
Chausson Flash 610
3 years
The curtain is to go behind the swivel seats, much like you would see on chausson or other MH's, difficulty is that the surround above the seats is plastic so cannot fit rails there, and above the surround is wood compartments but giving only a little amount of fixing room, Velcro may not be strong enough as the shape would be a semi circle with corners, and a light but fairly med weight curtain.
Thanks for your replies sure we will find something that might do it.
Etap
Mar 16, 2010
3,057
30,759
Carmarthenshire
In between
Since 1988
Etap
My TEC has a lightweight curtain attached by press studs. It must have been done at the factory because it is the same material as the rest of the curtains in the van.:xsmile:
Hollyberry
5,518
42,265
New Forest.
None.
4yrs
I hung a large duvet cover by trapping it in the locker doors--not pretty but definitely kept habitation area warmer. Just took it down in the day.
injebreck99
1,706
1,795
norfolk
Low profile C Class
Since 1997
I sometimes wish that we had a curtain on a rail to replace those irritating concertina blinds that cut vision and rattle/creak.:swear2:
motorhome42
48
15
North Tyneside
Auto-Trail
Since 2009
We used a spring loaded extending net curtain rail. Works for us and definitely helps to cut down on cold draughts.
LARRY99
298
444
South wales
C class Rv/ Dethleff
Ages
What about the plastic covered wire curtain rail that's made to go around curves , the stuff you cut to length and screw a metal eye into the end ,,, that and a few small hooks in the right place should do it, and it will fold up with the curtain when you stow it
Cal54
3,806
62,035
Southport, UK
Leisuredrive Renoir
Since 1996
Etap; are you sure you want a permanently fitted curtain? They can become a nuisance and get in the way at times. Personally I would look at something that you put up only when necessary, and was light enough to tuck away into a cupboard when not needed.
Sep 23, 2013
2,585
8,773
Lincs
Globecar Campscout
I used press studs screwed to the wood. Looks fairly neat - more so than velcro strips or a curtain rail would. The fixing area is right in my eyeline.
We made a thermal lightproof curtain - one layer of lightproof material, a layer of thermal insulation & then a layer of lining material. It's very effective - keeps the heat in, stops draughts & means that when parked up, you can't tell from outside whether the van is occupied or just parked, which can be handy sometimes! (y)
It folds up & goes in the over cab storage area when not in use. It would always be in the way if it just pushed back on a curtain rail.
Mar 11, 2014
934
1,331
Lincs
PVC
Since 2010
Hmm. May have to have a rethink on my plan as this sounds better.
Having had a quick look something like this will probably do the job.
Broken Link Removed
I've already got a load of thermal blackout curtain lining from another project to use for the curtain
Xabia
1,186
821
Rural Nottinghamshire and Spain
Since 1996
Have you considered those spring loaded curtain rails that work by exerting pressure against the walls that they are placed between. You could put it up at night and away during the day.
Like these: Broken Link Removed
Mike
2,585
8,773
Lincs
Globecar Campscout
Broken Link Removed
Yep - that's what I used. Different packet, but same contents.
I did try the expanding pole idea, but the van sides slope in a bit towards the top, so they just slid down. The sides are dimpled plastic, so very little grip. We wanted to have the curtain up on the move too - it means you can keep the cab heat in the cab & not worry about trying to heat the whole van with a heater not designed to do that. Depends what I'm going to do at journey's end - my van gets used like a car, so if I'm going to park, get out of the van & go into a building, there is no need to try & keep the back warm.
Minxy
32,659
66,565
E Yorks
Carthago Compactline
If it is to go at the rear of the cab between the cab seats and the habitation area then what about good old fashioned curtain net wire threaded through the top of a couple of curtains and hooked up at either end with a hook in the centre to support the centre of the wire so it would still allow you to get at stuff in the cab if you needed to. You could easily leave it up during the day if you wanted by just pullin gthe curtains to each side, leave them in place to keep the heat in the cab when travelling, or just unhook the lot and fold it to store.
As we use our cab seats swivelled round for our half dinette and also have fitted cab concertina blinds I have other methods of increasing the insulation - the first is to put some internal thermal blind pads between the concertina blinds and the windscreen and door glass which makes a lot of difference (the suction cubs on them and the blinds hold them in place) in addition I have made some curtain panels from some old thermal backed curtains that I had which have Velcro sewn on the tops which attached to Velcro which I've stuck around the top of the cab - these can be easily and quickly fitted to give more insulation if needs be and/or cut down the amount of light entering the cab area so the dogs don't wake up so early!!! They come off quickly if needs be and can be easily stored.
Aug 19, 2013
2,960
4,291
Wells, Somerset
Elddis 115
since 2004
We use the plastic covered net curtain wire idea held by a single screw-in eyelet at the centre point, just in front of the overcab so that it hangs behind the front seats. Since the overcab cupboard has no door, we just roll up tuck in each side of the curtain when not in use, it takes up little space but is ready to roll down instantly, should they be required for an instant car park comfort stop, or of course overnight. It does help on cold nights.
Theonlysue
6,104
7,383
Essex
As Executive 50th an
Not long enough!
Velcro nice and easy
movan
21,492
120,753
Moving around
Burstner
since07
Hope @GJH sees this and can explain better than me... They used the bottom pieces of a walking stick cut out to form a 'rest' for a pole The curtains can then be drawn back to one side when not needed. Hopefully, they will see this. It was a brilliant idea. :)
Sep 23, 2013
2,585
8,773
Lincs
Globecar Campscout
One of the reasons that I went with press studs rather than curtain wire & hooks, apart from aesthetics, is that the hooks would be at my eye level. It's also a point that my head passes very close to as I move in & out of the van & through to the front seats. The consequences of a slip or just a misjudgement didn't bear thinking about.
I expect the press stud would still hurt & I have hit my head on the woodwork a time or too, but they are not quite so likely to rip my eye out or slash my cheek open.
Sep 16, 2010
3,010
2,858
Bungay Suffolk
Autotrail TrackerEKS
Since 2010
Minx's Idea of covering the glass first, will save you a lot of condensation.. Then a velcro'd 2 piece curtain will do the rest of the job..
Badknee
7,408
412,824
notloB
Vantage Neo
Living the dream.
We wanted to close the cab off so today we bought a spring loaded shower curtain rail and a set of thermal lined curtains from Dunelm, looks good and hopefully works well :xgrin:
Were away next week, off to Devon so will take some piccys and let you know how they work.
Feb 9, 2008
8,951
18,708
Corby, Northants
Coach Built
My wife! who sees a lot of things I do not !!! said lower the sun visors, put our throw (seat cover, Large) across both of them and raise back to the normal position. Bingo! Brilliant, quick and absolutly no cost. If it was left to me I would have been employing NASA technology and NASA pricing.
mjltigger
1,619
2,672
Trowbridge
Autotrail Dakota Max
Our van had a curtain held up with what I think of as net curtain wires. It did my head in so I got rid of it as soon as we had some internal screens.
Mind you, our cab heating on the move keeps the whole interior toasty warm.. gotta love Fords
