Thetford Toilet Model (1 Viewer)
milpol1
80
24
Earth
2013 Hymer
Since 2011
Im trying to locate the model number of my Thetford loo, I believe it may be of the C200 series, I cant locate it, i dont ha record of it in the documents. The reason I need that is to try and find out how it functions as to flushing.....Do I flush it from main water tank or is it filled by the cassette. There is also a blue button which I presume is the flush button, I pressed it earlier but nowt happend, does the slide have to be open before it flushes.
Any help appreciated
Regards
Dave
camocam1
1,112
788
Elgin,Moray,Scotland
bailey approach 760 se
since 2012
Given the blue button it sound like the C200 same as mine if it is it is fed from your bulk tank no holding tank
If not flushing sounds like either your pump is not on a fuse has gone also check that you have not pulled out a connection in the cassette locker
Slide does not ned to be open but I usually open mine before flushing
Terry
11,932
9,082
Lincolnshire
Can't remember ;)
Hi it sounds like the c200 electric flush model -it needs wireing to the leccy /control panel needs to be turned on :winky: plumbed into your clean water tank
terry
daisy mae
675
597
Leicestershire
C class Coachbuilt
I`m a newbie, now 1 year
Hi,
I have the same toilet, it is an electric flush, on mine anyway, press the flush knob down while turning in an anticlockwise direction, the turning motion opens the valve blade emptying the toilet bowl, the Thetfoerd C-200CS and C200S have a built in flush-water tank, on the caravan I leave the technical stuff to my husband, on my MH I am learning slowly myself. well trying to. :ROFLMAO:
daisy mae
675
597
Leicestershire
C class Coachbuilt
Forgot to say, it does not use water from the MH fresh water tank, toilet has it`s own. electric does need to be switched on.
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
Some are fed from the main fresh water tank, others have a separate flush tank with a handle. If yours has a button it is most likely fed from the fresh tank. The C200 series is very common. Have a look here and you will see that you can download manuals and repair instructions. You should be able to identify which model you have.
http://www.thetford-europe.com/en/service.aspx
M
milpol1
80
24
Earth
2013 Hymer
Since 2011
Just gotta locate the on/off switch for the water pump now
M
milpol1
80
24
Earth
2013 Hymer
Since 2011
Sorted.....Thanks for the replies.
