the tyre pressure (1 Viewer)
duetto owner
216
north surrey
hi top
in first year
see this on halfords web for inflating tyres up to 100psi, apparently you set the digital pressure and it cuts off when the tyre reaches that pressure.
our local halfords are hopless but seen this on their web.
my old car one burnt out.
after any advice comments on this item or similar suggestions.
duetto owner
duetto owner
216
north surrey
hi top
in first year
not sure if it will inflate with a 3.5 ton vehicle or if just for cars. Other webs show its only goes to 50psi now having doubts, got no contact info for michelin.
2,337
10,147
duetto owner
duetto owner
216
north surrey
hi top
in first year
Halfords Rapid Digital Tyre Inflator
looks good too but same questions will it be ok on 3.5 MH and go above 50psi?
Douglas
2,835
400
South Wales,
I picked up a cheapo from Lidl in Portugal 3 or 4 years ago for 12 euro, its still going strong, I think the secret is not to use it for more then 10 minuets at a time and lit it cool down before using again.
Doug...
Feb 25, 2008
232
96
Barril da Alva, Portugal
Caravan
on and off for the whole of my existance
hot air!!
Jim, the truck air was rated as being good, but the reason you can't find one is they are c..p. had one, burnt out in ten mins, swapped for another and would not pump above 20 psi.
I think that as long as the pump does say pump 50 psi, it does not matter what its holding up, it will still be 50 psi. Happy to be corrected.
Nothing like a tiny compressor with on board tanks
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
pressure is pressure, it just takes longer to build up. i use a gast air compressor.it works the airbrakes on trailer, it blows tyres up really quick but a bit expensive at nearly 600 quid for a 24volt .they do a 12v version .
madbluemad
Banned
Jan 26, 2008
3,327
239
spain
just looking
since 1980
Ive got one of these from Halfords and it works a treat. Have not used it to inflate from flat but topped up tyres to 70psi. The trick is, dont hammer it
Cheers
Jim
:Smile:
DESCO
2,646
266
London
low profile
18 years +12 years tugging
Cheers
Jim
:Smile:
Must agree this has been my experience also
Dave:thumb:
duetto owner
duetto owner
216
north surrey
hi top
in first year
Well finally got one.
michelin said theirs was not suitable as these pressures would burn the motor out after a few uses, Halfords more or less said the same about all their ones when the shop rang halfords tech support.
ended up in local car parts shop and got a RAC800 for £35 which runs of recharge battery, mains, and 12v.
The guage is a poor analouge type so bought a small digital pressure guage to make up for it.
if you decide to get a RAC800 shop around internet prices were a RIP OFF some charging up to £68 for same item.
duetto owner
duetto owner
216
north surrey
hi top
in first year
Well still no better off
the RAC800 turned out to be utter junk. the gauge read the tyre as 120psi when it was 49, but i had a decent tyre guage so did not worry at this stage. Plugged it in after 6 mins checked the psi it had only gone up 2psi tried again and the machine stopped indicating it needed charging it had just spent 20 hours on charge and showed fully charged a few moments earlier.
took it back got a different machine, it worked ok running on 12v cigar lighter socket but the lead would not reach the back wheels despite saying on the box for van use.
that went back, looks like its using garage forecourts which i am not keen on as i always check tyres cold.
