Thacham Alarm problems (2 Viewers)
Bluemooner
1,723
8,074
Ribble Valley
Dreamseeker Fifth Wheel
4 years
We had a hab service done last week and ever since then every time i try and set the alarm i get a couple of extra beeps and then about a minute later the alarm goes off is an easy fix available or will it have to go back in? :cry:
17,635
43,369
thatcham is a security standard (in the case of vehicle alarms) and not the manufacturer. therefore working out what fault it may be is a bit difficult. try resetting the alarm system as per manufacturers instructions and make sure all doors are closed including the bonnet and that the switches havent been knocked.
on many alarms 2 beeps is a door open warning
Bluemooner
Bluemooner
1,723
8,074
Ribble Valley
4 years
Thanks for a quick reply problem is i haven't got any instructions (that i can understand) i found the bonnet push in button and that looks ok
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
You need to identify the make first.
Are there any identifying stickers on the windows or key-fob?
Does the alarm have a bike-rack loop (a cable with a multi-pin connector at one end and a pull-apart link between the two wires at the other?
Mar 22, 2011
477
406
NE Wales
Chausson Best of 10
Since Feb 2013….2nd Van
I have a Cobra. The beeps on my van normally indicate a door open?
Bluemooner
Bluemooner
1,723
8,074
Ribble Valley
4 years
Thanks for the reply's i will have another look before i take it back to dealers:Doh:
rainbow chasers
3,680
1,725
Mid Cornwall
Various
As journeyman says, they usually beep to warn you of an open door. Usual culprit is the bonnet sensor breaking up inside ....they look ok, but do take alot of grief!
Take some wire, an insulated pair of pliers and remove the connector from the back of the switch. Bend the wire so is goes into both ends of the connector (using pliers so you don't risk zapping yourself!)
Place somewhere where it cannot touch anything/tape up with inulating tape. No need to close the bonnet - you have just folled it into thinking it is.
Reset the alarm, and see if the fault is gone or not. If it has, replace the switch - if not, move onto the next one.:thumb:
canopus
6,140
10,265
rural Lincolnshire
Carado CV640 Pro
I had a similar problem with my Cobra alarm, and discovered that the door contact on the garage door had become dislodged whilst unloading and was obviously not making contact when the door was closed. I just put the contact back in place and bingo problem sorted. :thumb:
There's a similar contact under the bonnet too.
motorhomer
680
418
South Shropshire
If the alarm has been triggered the inside warning will flash, and it flashes a code which identifies what caused the alarm to be triggered.
You need to know the model of alarm. You can then find a manual.
http://www.manualslib.com/download/29161/Cobra-8165.html
The link has manuals for cobras.
Bluemooner
Bluemooner
1,723
8,074
Ribble Valley
4 years
Thanks for all your help just been having a look and found the wire connecting to the bonnet alarm had come off so feeling pleased with myself i put it back on and the alarm still wouldn't set bugger
Steve_UK
37
17
Mid Sussex
Auto-Sleeper Clubman GL
Since May 2012
...And did you follow Rainbow Chaser's advice in post #7 to check the switch?
What was the outcome?
Bluemooner
Bluemooner
1,723
8,074
Ribble Valley
4 years
Not yet Steve but i probably will tomorrow i still cant understand why the wire was off
Bluemooner
Bluemooner
1,723
8,074
Ribble Valley
4 years
The alarm type is Autowatch 695 can, if the wire had come off would it mean the alarm needs re setting and if so does anybody know how to do it
17,635
43,369
if you need the installers notes and fault finding guide, download the link below and print off. if you pass this on to your chosen auto electrician it will save time and money
Bluemooner
Bluemooner
1,723
8,074
Ribble Valley
4 years
Thanks for that Big1 i have rung my dealer up who were ringing me back but never did i was hoping i wouldn't have to take it in but it is still under warranty
