Tablet Sat Nav advice please
Discussion in 'Tech/Mech General' started by Mark James, Aug 5, 2016.
  1. Mark James
    Mark James Funster
    Jun 1, 2016
    26
    13
    New Forest
    I have seen a few posts on here about specific satnav units ie Garmin Camper or Chinese 7" units but i am looking to utilize one of the number of tablets i have at home, I intend to use either the 7" or 10" android units specifically as they have dedicated GPS chips, does anyone have any advice on android satnav apps to use for the MH, is it worth going for the dedicated MH/Truck apps for the vehicle dimensions?
    thanks in advance for any help on this.
    Mark
  2. Mark James
    Mark James Funster
    Jun 1, 2016
    26
    13
    New Forest
    Jeesh just seen the mess i made of spelling the Thread title..... i need a few days away in the MH, and then managed to find out how to edit it... still learning bear with me :)
  3. John Laidler
    John Laidler Funster
    Jan 9, 2013
    8,763
    11,960
    Plympton, Devon
    CoPilot is well reviewed on here. I tried it with my 9“ tablet but had two problems. The tablet and the mount I bought were too big really for my dashboard. It would be better with a 7" tablet. The other problem was the battery ran flat even when permanently connected to a USB socket. To overcome this I think the USB socket (2A) needs to be very close to the tablet so you can use a very short lead. Even then I'm not sure my Nexus 9 tablet could be run all day as it uses a lot of power.
    • Thanks Thanks x 1
  4. chaser
    chaser Funster
    Feb 16, 2013
    7,484
    8,438
    uttoxeter
    Try " here maps" look for it in the play store, it's now called here wego fantastic, as good as any dedicated sat nav, it's owned by bmw and what is in there cars.
    And best of all free, and got downloadable maps so it works off line.
    • Like Like x 1
    • Thanks Thanks x 1
  5. Wagoneer
    Wagoneer Funster
    Jul 6, 2016
    189
    92
    Sussex
    I run CoPilot on a tablet and found the battery drained when plugged into a 2amp USB. I now switch the tablet to "aeroplane" mode - this seems to have cured the problem.
    • Like Like x 1
    • Thanks Thanks x 1
  6. golly
    golly Funster
    Aug 16, 2009
    1,142
    2,076
    Co Durham
    I bought Co-Pilot caravan/camper couple of weeks ago, tried it against my Garmin, within half a mile of home it wanted to take me on a country road I would think twice about going in the car ! then when I ignored that it wanted me to go down a unmade track. Needles to say I haven't used it since, that's £39 quid I wasted.
    • Thanks Thanks x 1
  7. PORKSTER
    PORKSTER Funster
    Sep 15, 2009
    968
    931
    Sussex coast
    I used Hudle 2 with no issues I did however turn other stuff off, Hudle died so now have nexus 7 with Copilot loaded and maps me. I have yet to try this but I am confident it will do the job I also have far to many motorhome related apps I should cut back a bit.
    • Thanks Thanks x 1
    • Funny Funny x 1
  8. androidGB
    androidGB Read Only Funster
    Dec 28, 2009
    152
    140
    Bristol
    I had Sygic on a tablet and also on a phone. I found that on the tablet (Samsung 7") it lagged badly when compared to the phone.
    I'm currently using a Garmin 660 from Aldi. I also have one on the Chinese versions but find the screen difficult to see in bright light with sunglasses
    Andrew
    • Thanks Thanks x 1
  9. bungy
    bungy Funster
    Jan 24, 2010
    2,250
    4,141
    Welsh marches
    you can also change the power setting in copilot to always use lower power mode. This is very effective, and all it does in all honesty is reduce the map redraw rates, barely noticeable in use, but does save the juice. I also tend to use the directions view so that the map is only visable when coming to junctions etc, again a major power save
    ive a 8inch tablet that uses a 2amp charger normally, but quite happily keeps its charge running from the .5amp usb power port on the stereo
    • Thanks Thanks x 1
    • Informative Informative x 1
  10. bungy
    bungy Funster
    Jan 24, 2010
    2,250
    4,141
    Welsh marches
    another fan of copilot here too
    lots of free alternatives around and have tried most of them myself but always come back to copliot for quite a few reasons. One of my favourites is being able to tweak the route planning to suit your driving style
    Its worth getting the free one first and try it out. Free one doesnt give you 3d view or hd voice but you can at least have a play with it and see whats what
    Also worth checking out the settings, quite a lot of comments about its failings are down to the settings not being adjusted for the device its running on - main one being power settings and map views
    • Thanks Thanks x 2
  11. rod_vw
    rod_vw Funster
    Jan 17, 2014
    36
    19
    Wellington, Telford, Shropshire
    We use CoPilot on a Hudl 2 successfully although still not up to the old MS Autoroute in my opinion. No problem with the Hudl charging using a genuine Hudl USB adapter in the 12v socket. Unfortunately I think it is not possible to get the genuine adapter since Tesco stopped selling the Hudl. I have both the original short power lead and a long version which is much thicker and was supplied with the adapter I think.
    Re CoPilot, can anyone tell me how to remove custom POIs and their Icon. I have read various help sites but still not managed to remove the custom additions completely, always left with the icon which I created incorrectly. All I really want to do is correct the icon.
    Rod
  12. Leftlegger
    Leftlegger Funster
    Sep 29, 2012
    418
    401
    N.somerset
    I've a samsung tablet with a holder bought off ebay.I've been using NavMii free and find it very good using rv/lorry route option its every bit as good if not better in some cases as my garmin.An odd advert when first starting up but easily closed and a small unobtrusive add to the top of the page which can be removed for a small sum ,£1.49 .
  13. Andysconcorde
    Andysconcorde Funster
    Mar 19, 2016
    15
    3
    France
    I've not had Copilot long but it chose better routes than our Garmin leaving UK and thro France. No problem keeping Nexus 7 charged from 12v usb but have shut down other apps.
  14. StitchesnFluff
    StitchesnFluff Funster
    Oct 18, 2014
    1,229
    520
    Salisbury
    I can recommend Sygic
  15. Hymie
    Hymie Funster
    Nov 29, 2013
    594
    676
    Essex
    I stick with my Chinese satnav since the Garmin took us onto the peripherique in April, did nearly 3000 miles on that trip and it never put a foot wrong.
    Hymie.
  16. hilldweller
    Dec 5, 2008
    27,221
    26,208
    Macclesfield
    Copilot Live. And strangely I'm just loading it on to a new phone I bought especially for it to use on my bike. The last phone it was on let me down in Italy a couple of weeks ago, it overheated.
    I've used it over tens years, can't fault it.
  17. sallylillian
    sallylillian Funster Life Member
    Oct 29, 2011
    893
    559
    Falmouth, Cornwall
    I think the icon, probably something.bmp will be found in the save folder or the users folder. If you cannot delete it or that does not kill it then just delete the POI set folder in the user folder and add the POI set again with the new .bmp and boot copilot. If the old.bmp and importantly the category remain you may need to create a new category with a slightly different name as you go through the install POI set at boot.
