Tabbert 570 Classic Cam belt
Discussion in 'Motorhome Chat' started by Demelza, Sep 25, 2011.
  1. Demelza
    Demelza Read Only Funster
    Aug 28, 2011
    69
    Cornwall
    In the never ending search for the right MH, today's viewing was another Tabbert 570 Fiat Ducato 2.5 Turbo 1991. Seller has no idea whether cam belt's been done so that would have to be done. Does anyone have any idea how much it would cost? Another thing was one of the windows fell out when he opened it! :Smile: It needs a couple of new hinged arm thingies. Would these be difficult to find for this model? Thanks
  2. Snowbird
    Snowbird Funster Life Member
    Apr 24, 2009
    10,284
    16,949
    Liverpool.
    What engine is it ???.
  3. Demelza
    Aug 28, 2011
    69
    Cornwall
    As I said in my post it's Fiat 2.5 Turbo.
  4. Demelza
    Aug 28, 2011
    69
    Cornwall
    Sorry being thick. Should have said diesel.
  5. Snowbird
    Apr 24, 2009
    10,284
    16,949
    Liverpool.
    The reason I asked was that some of the FFBs had the Citroen engine from the CX which has 2 cambelts. The reason behind this is that they were all built on the Seval cab chassis which was a marriage of Citroen,Peugeot,Talbot. They used whichever engines were lying around at the time.:Eeek:
    • Like it Like it x 1
  6. Demelza
    Aug 28, 2011
    69
    Cornwall
    Ok thanks. It's definitely a Fiat Ducato. He had a manual and it's registered as that on the DVLA doc. Does that make sense? However, for future reference, what do you think would be the worst case scenario costwise, if we came across one that has two cam belts?
    Cheers.
  7. Snowbird
    Apr 24, 2009
    10,284
    16,949
    Liverpool.
    Being badged as a Fiat and having Fiat on the logbook means nothing with Seval chassis. A Peugeot can have a Citroen engine as I found out after taking the cambelt cover off.
    I haven't a clue what a garage would charge to do a cambelt change as I don't use them. Whilst having the cambelt changed have the gearbox oil changed at the same time with semi synthetic. make sure they drain both drain plugs and refill through the speedo cable...Its imperative that this is done correctly on the older Sevals.
  8. nucs200
    nucs200 Read Only Funster
    Sep 4, 2011
    64
    26
    UK
    have you seen the ffb 660 on ebay it could be ok has a lot of extras maybe worth a look. how much is the 570 where did you see that one just out of interest
  9. Demelza
    Aug 28, 2011
    69
    Cornwall
    Oh Ok thanks. My understanding of all the technical stuff is very limited as I'm sure you can guess! :Smile: Unfortunately I have no idea what a Seval chassis is. As we seem to now have short listed the Tabbert and a 1996 Authohomes Merlin VW transporter 2.4 TD - cam belt was done at 41,000 it's got 45,000 on the clock, I think for us, being novices, the VW will be the one to go for. We have been seduced by the character of the Tabbert but think that we should shelve that idea until we know a bit more about what we are doing! Thanks once again for your help and expertise.
  10. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,389
    5,415
    East Sussex 01-580-881288
  11. Demelza
    Aug 28, 2011
    69
    Cornwall
    Yes, we've seen that thanks. My Oh does all the looking. I think the 570 was on Autotrader.
  12. UKMotorhomes
    UKMotorhomes Read Only Funster
    Mar 6, 2011
    49
    44
    Oxfordshire
    We had an FFB660 Classic a few years ago, also 1991.
    Very well built internally but one thing to watch with them is any sign of corrosion in the aluminium skin above the cab side windows. The roof joint above the cab seems to be susceptible to leaks and damp eventually causes the aluminium skin to corrode from the inside. You see quite a lot of them with this area patched.
    I think the window arms should be standard and readily available, from memory the captains seats were Sportscraft so parts might still be available.
    Andy
