Swing table (1 Viewer)
EX51SSS
6,073
28,561
North Manchester
Hymer Exsis A Class
since 2007
Has anyone a recommendation where I can get a swing table. The arm and fittings are available at O'learys at Beverley at around £70 plus a round table top at £50. Thought about a motorhome scrapyard regarding the top though. Any suggestions?
Mar 25, 2013
1,274
39,666
Maidstone Kent
Dethleffs Esprit 160
Since 2013
We were quoted £450 by Swift :Eeek: so £120 is a good price. We got the fittings from eBay for £90 and table top hand made,from local kitchen fitter for £50.
EX51SSS
EX51SSS
6,073
28,561
North Manchester
Hymer Exsis A Class
since 2007
Brilliant. I thought it was a pretty decent price but can't do any harm to ask.
Minxy
32,651
66,548
E Yorks
Carthago Compactline
You don't necessarily need to use a MH table top, think of places like Ikea etc that have cheap tables which you could use the top from, or even chopping boards etc!
EX51SSS
EX51SSS
6,073
28,561
North Manchester
Hymer Exsis A Class
since 2007
What a brilliant idea. Thank you very much.
May 7, 2011
4,809
47,944
Cornwall Gorran Haven
T Line 785
motorhoming since 1979
I bought one from O'leary's, the only problem I found was the leg/arm £75 is a bit heavy duty (pipe is about an inch & three quarters in diameter)the table I bought from another supplier ( from memory about £ 35 ) worked Ok ,sold it with the motor home .
EX51SSS
EX51SSS
6,073
28,561
North Manchester
Hymer Exsis A Class
since 2007
I thought exactly about the weight too. Don't suppose you remember who you obtained it from.
The one I've seen from O' learys is very good but, as you infer, probably too good.
Minxy
32,651
66,548
E Yorks
Round 40cm table top on Ebay @ £28 + £5.50 postage:
Cherry/wood effect finish:
http://www.ebay.co.uk/itm/400MM-CHE...462973?hash=item3f64e1db3d:g:Ig0AAOxyEoFSWo5h
Grey speckle finish:
http://www.ebay.co.uk/itm/400mm-ROU...583203?hash=item3cfd4aeae3:g:B14AAOxydINSWovz
Square 60cm grey speckle finish one @ £35 + £3.50 postage:
http://www.ebay.co.uk/itm/600mm-x-6...hash=item3aa5837d11:m:m0ljMUsnaoMKrbgEbYcsF6A
They do other sizes/colours too.
Swivel table leg:
EX51SSS
EX51SSS
6,073
28,561
North Manchester
Hymer Exsis A Class
since 2007
Wow minxygirl, you certainly know e bay. Those sound perfect particularly the grey one. I'd probably go for the grey circular but I suspect it'll be wood effect we'll get. Thank you very very much.
Minxy
32,651
66,548
E Yorks
I like the 'egg' shaped ones! :D
If you're not fussy about having new then also look at coffee tables, small kitchen tables, even office tables, on Gumtree etc and Ebay at a fraction of the price of a new top.
I used a large 2ft diameter 'lazy Susan' for a table in a previous MH - I just removed the bottom swivel bit and put the 'Susan' on top of my existing table pole. In another I used a cranked leg (similar to the O'Leary one and they ARE heavy!) along with the top off a dining table I'd got at a car boot sale for £3!
Unfortunately it's the leg that cost the most but if you're not in a hurry you should be able to pick one of the cranked ones up cheaper.
