Suspension upgrade (1 Viewer)
Nov 6, 2013
3,201
229,849
East Sussex
Hymer B574DL
Since 2011 (tugger for 20 before that)
Hi guys and gals
I have a 2015 Swift BoleroFB with a dinette which has a current weight restriction of 3700kg
I am having an issue with my rear suspension. To carry the scooter we have I need to upgrade from 3700 to around 4000.
I have been told this can be achieved by fitting air suspension in place of the rubber stops. My problem is that I have no rubber stops :Eeek:
My rear suspension looks like this:
Can anybody advise what I need to do?
TIA
John.
SandraL
1,373
985
Somerset
Hymer b694sl
You have an alko torsion bar axle which does not have rubber stops. Those are fitted on fiat leaf springs. Search for alko air suspension and get wallet ready.
icantremember
8,336
17,558
Near to Watton in Norfolk
Hymer T-SL668
since 2005
As above ... definitely an Al-Ko chassis which we have on our Augusta and have AS-Air suspension fitted, which although not cheap is a great system.
In case you are not aware, some Al-Ko axles have a couple of grease nipples which require regular attention ...............
Copied from the Al-Ko web site:
Should I grease my AL-KO axles?
Yes. We recommend greasing your AL-KO axles every 20,000 Km, or once a year whichever comes sooner.
Ideally jack the motorhome so both wheels are off the ground. The grease nipples are situated on the axle tube.
5-7 pumps of a hand grease gun for each side should be sufficient, until resistance is felt. Excess greasing could break the seals and fill the torsion tube.
We recommend 3 greases: Shell Retinax LX, Co. Kluber GL 1501 and Co. CONDA 3746 SP.
Failure to grease regularly could result in a requirement to replace the axles.
icantremember
8,336
17,558
Hymer T-SL668
since 2005
You should be able to make out one nipple in this image covered with a yellow plastic cap ... only a couple of inches inside the chassis member.
Baycott
Nov 6, 2013
3,201
229,849
East Sussex
Hymer B574DL
Thanks for your input everybody,
It looks like I need to get underneath and see if I have an 'up going chassis' :Eeek:
Don't know what I can do if it can't be upgraded :(
icantremember
8,336
17,558
Hymer T-SL668
since 2005
I'd not heard of the problem with "up-going chassis" ... you may find it is only certain kits that have the problem.
If you are going to Peterborough it would be worth talking to Phil on the as-airsuspension stand and I'm sure he will look at your m/h and give you the necessary info.
I have used them on two motorhomes and can highly recommend them for quality, service and all round great people.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Of course my axle pictured is already 2400kg so doesn't need help
PP Bear
7,818
28,834
Kent, UK
Auto Trail Dakota SE
Yes defo make sure you grease the rear suspension :)
That's a great picture @icantremember posted. Mines similar, only it has a shield covering the water tanks. You'll see the yellow covers over the grease nipples, just need to pop them off and add grease (easily said) :)
tonka
10,834
21,544
Cannock, Staffs
A class Burstner 800
Since 2000
WTF.. !!!
Someone told me to come on here because there was loads of "Nipple pictures"... I am not impressed so far..
:rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl:
Techno
Jul 28, 2010
15,475
20,756
May 2010
Do you happen to know what the difference between your 2400 and my 2000 suspension is Andy?
400 ?
Seriously do you know what size wheels/tyres you have? Mine are 16"225/75 1250kg per wheel and the ALKO HEAVY chassis
Baycott
Nov 6, 2013
3,201
229,849
East Sussex
Hymer B574DL
400 ?
It says on my tyres 225/75R16CP so I guess they are the same as yours..?
Techno
Jul 28, 2010
15,475
20,756
May 2010
Yes
What does your weight plate say under the bonnet?
It should give you
Axle 1 .....kg
Axle 2 .....kg
Techno
Jul 28, 2010
15,475
20,756
May 2010
Yes It must be the light or standard chassis then. Have you spoken to SVtech? They will tell you what is possible if anything at all.
Mine is the heavy Alko and 2100 front 2400 rear
Baycott
Nov 6, 2013
3,201
229,849
East Sussex
Hymer B574DL
Have emailed Gareth at SVTech and am waiting for a reply.
Techno
Jul 28, 2010
15,475
20,756
May 2010
The wheels and tyres can take 2500kg (pair) so its a matter of whether they can overcome the axle rating
53,495
150,312
As Andy says from that plate yours looks like the light chassis your max rear axle loading with air will be be 2240 & you will need 225 secition tyres assuming 15" wheels, max gross weight will be 3850kg.
As you are aready running at 3700 depending on your axle loadings you may not be able to achive the extra rear axle loading you need.
SandraL
1,373
985
Somerset
Hymer b694sl
Going back to first post, this is to fit scooter presumably on a rack.
http://www.watling-towbars.co.uk/motorhome_axle_loads.html
url gives calculator to see how it would affect rear axle load. Do you have current rear axle load from a weigh bridge? and GVW in touring trim?
With both of above figures( existing axle load plus scooter/rack) you can work out how much extra load capacity you need on rear axle.
To get dvla to increase weights they will need "approved engineers" report, the engineer will have to approve the changes you make. So best to speak to them to ensure this is possible. SV Tech are the best known,offer free telephone advice, charge about £300 ish. Others are available from £100 ish.
Usual method is air bags and ensure rear tyre load index is enough. I dont know how far the rear axle load can be increased but likely this will be needed as well as Overall ( GVW) weight of vehicle.
Baycott
Nov 6, 2013
3,201
229,849
East Sussex
Hymer B574DL
I did weigh the van with the tow bar fitted and half a tank of water and the rear axle we at 1950kg so almost at maximum. Scooter weighs 95kg and the rack about 60kg so I need to increase by at least 150kg to be safe.
Techno
Jul 28, 2010
15,475
20,756
May 2010
Cheapest option is side loading bike trailer
