Alko axle greasing is not at all difficult!
Discussion in 'Tech/Mech General' started by Techno, Sep 17, 2014.
  1. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,182
    14,954
    Leeds the one up North
    There are many misguided posts all over the web about this so here it is simplified.
    Tales of having to jack up so both rear wheels are off the ground at the same time is both unnecessary and unsafe.
    All you need is reasonably level ground with the engine in gear and the wheels chocked.
    The handbrake must be OFF!
    One side at a time just lift the chassis as though you were going to change the wheel.
    Then with a properly bled grease gun pump in several strokes of lithium high melting point grease.
    Repeat for the other side and replace the nipple covers.
    How easy is that
    [​IMG]
    • Like Like x 7
    • Useful Useful x 1
    • Informative Informative x 1
  2. laneside
    laneside Funster
    Aug 14, 2009
    3,536
    5,489
    Oradour sur Vayres
    Depends who built the van on some models the grease nipple is not accessible without dropping the axle. Daft I agree
  3. Techno
    Jul 28, 2010
    14,182
    14,954
    Sorry I only play with proper vans like Rapidos :D
  4. laneside
    laneside Funster
    Aug 14, 2009
    3,536
    5,489
    Oradour sur Vayres
    Yep me also
    • Like Like x 1
  5. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,274
    7,935
    West Norfolk
    Did you find any illegal immigrants under there?:Eeek:
    • Like Like x 1
  6. Techno
    Jul 28, 2010
    14,182
    14,954
    Actually I did appraise the possibility of this happening and it's a deffo no go for the poor sods (y)
    • Like Like x 1
  7. Rayb182
    Rayb182 Funster Life Member
    Nov 13, 2009
    1,483
    1,613
    Great Bentley
    Looks like mine underneath, done mine a couple weeks back, one grease nipple wasn't letting any grease through, unscrewed it put a new nipple in, while nipple was out found there was no grease in axle, good job I did it.
    • Like Like x 1
  8. Al1
    Al1 Read Only Funster
    Jul 20, 2008
    37
    10
    How much grease do you put in?
  9. Techno
    Jul 28, 2010
    14,182
    14,954
    Check that grease is coming out the hose end before going on and after releasing from the nipple so you know it was going in.
    • Like Like x 1
  10. Techno
    Jul 28, 2010
    14,182
    14,954
    Good gun guide
    • Like Like x 1
  11. mitzimad
    mitzimad Funster
    Jan 28, 2008
    3,046
    3,429
    walthamstow east london
    seeing that grease gun took me back i used to grease my brothers artic tand trailer every month for pocket money usually had more on me than on the motor
    • Like Like x 1
  12. Kool Kroozer
    Kool Kroozer Funster
    Apr 19, 2014
    1,108
    1,813
    Cannock Staffordshire
    That a Gas tank i see at the far end Techno ?
  13. Techno
    Jul 28, 2010
    14,182
    14,954
    Yes
  14. ivorantony
    ivorantony Funster
    Jan 22, 2013
    490
    514
    London SE
    Some Alko chassis don't have grease nipples, and are sealed for life,
    Mine is that type,
    but I would have preferred some then at least you know it's lubricated
    • Like Like x 2
  15. icantremember
    icantremember Funster
    Sep 2, 2010
    5,219
    7,309
    Nr Watton in Norfolk
    I agree with you Andy that it is a simple job and I do my own regularly .... however I would not work under any vehicle supported on a scissor or hydraulic jack without using axle stands and I'm sure yours are just out of the picture. To enable the axle to hang free the stands need to be under the chassis and not the axle.
  16. Techno
    Jul 28, 2010
    14,182
    14,954
    No as the wheel is not removed and there is more than enough clearance under my van for this job.
    [​IMG]
  17. icantremember
    Sep 2, 2010
    5,219
    7,309
    I'm sorry to dissagree on this point, maybe mine is lower or I am of larger proportions but I would still not risk it without the stands and would not recommend anyone else does ..... it doesn't add much time to the job and my fire service training has taught me that safety should be a prime concern at all times.
    • Like Like x 1
  18. Techno
    Jul 28, 2010
    14,182
    14,954
    Yes you must do your own risk assessment with any job.
  19. SC 05 OUT
    SC 05 OUT Funster
    Apr 4, 2009
    3,289
    7,587
    doncaster
    tell the truth you greased all over the axle didn't you
    • Like Like x 1
  20. longdog
    longdog Funster
    Apr 16, 2013
    233
    232
    Swansea, South Wales
    Good post, thanks :)
