Supermarket diesel (1 Viewer)
Jan 2, 2017
592
607
Autocruise Starspirit
7 years
I've been warned about using cheap diesel from the likes of TESCOS because of it's inferior quality and blending. I now use BP. What do other Funsters do?
Derbyshire wanderer
1,299
2,407
Derbyshire
15 years
Use the cheapest all the time. It all comes from the same refineries using the same pipes.
The fancy and dearer options are dosed with additives but the actual fuel is the same product.
Some use the 'super' product and get supposedly more mpg and/or power but I don't believe the extra cost is VFM.
Supermarkets cannot afford to sell crap fuel but usually keep the cost down by subsidies as they want customer loyalty
Sheldon C
61
182
Aberdeenshire
Euromobil 695EB Profila
Since 1995
I find ignoring the unsubstantiated scare stories about the quality of diesel fuel from supermarkets the best thing.
As there are not many reports of terminal engine failure attributed to Supermarket fuel, I feel happy to stick it into my motors.
MC 55 FUN
3,432
6,347
Rural South West Wales.
2015 Majestic 195
Since 20th Feb' 2016
'' Supermarket fuel '' does not & never has existed, however fuel sold by supermarkets & sourced from the same 6 or 7 refineries as all other fuel sold in the U.K. does.
19,434
30,589
I have heard all the arguments that it's all the same etc etc but I never use supermarket stuff all the same, and I even use the super from time to time.
D
Deleted member 29692
This topic crops up once every couple of months and it's utter unadulterated nonsense. (y)
All fuel sold in the UK for cars has to meet the same standard. Surely nobody in their right mind seriously thinks the "brand name" garages are voluntarily exceeding that standard?
@DuxDeluxe one for you if you can be bothered to explain it yet again (y)
wanderer
643
769
huntingdon
a class Arto
This is another of those argument threads ,if you use the supermarket diesel you are hardly likely to believe its better to use the more expensive stuff . If you pay the extra it is because you think your vehicle runs better and further . I am the same as Martin and always use the super when abroad .
Two on Tour
10,394
51,455
Elddis Autoquest 175
I have a Nissan Navara 4 x 4 and if I use supermarket diesel it runs fine until I accelerate hard and then it will jump into limp mode which usually happens when I'm speeding up to join traffic via a slip road, not and ideal place to loose all power.
It then requires a switch off for about 30 seconds for it to reset the system. Start it up again and it's fine until next over exuberance with the throttle.
Not knowing why this was happening at the time I took it into the main dealer for diagnostics on their code reader. When they retrieved the codes I was asked where I purchased my fuel from normally and when I replied Tesco's the reply came back that that was likely to be the cause of my problem as they had see the same problem on other Navaras and the common denominator was some supermarket diesel.
I was a little sceptical but I have to say that after filling up with branded diesel and the supermarket diesel passing out of the system it ran as right as rain until it started doing it again and I found that my wife forgot and filled up at Tesco's.
Branded fuel in from then on and no problems.
This may only be a problem with Navaras of that engine type but for me and my Navara supermarket diesel is a no no.
34127
Last time this question was asked (Nov 2016) there was well over 100 replies so I doubt you will get a definitive answer.
maxi77
892
560
Kingdom of Fife
coacbuilt
newbie
Sainsburys sued one of the major fuel companies over suggestions supermarket fuel was inferior and won big damages. It seems to be a bit like fact that generic painkillers are just as good as the 'magic' big brands
Jan 31, 2016
1,117
606
Halifax
A Class Rapido 9097F
June 2016
I test tesco, asda, sainsbury, Morrisons, BP and Shell a while back
Tesco was worse followed by Sainsbury in terms of MPG however Morrissons was top only beaten by Shell however for price difference I use Morrisons
D
I've pretty much only used Tesco fuel for years unless I'm away somewhere in which case I use whatever I can find when I need it.
That's both petrol and diesel in cars (performance and 4x4) bikes (performance and not) and the motorhome.
Never had the slightest inkling of an issue and there's never been any difference in either performance or mpg when I've used something different.
7
7735
I had the same problem on my Mercedes I was told it was the EGR valve sticking, no mention of fuel, I think it's all the same. Comes from the same same refineries.
Spongy
Charlie
3,211
3,639
Herefordshire / Worcestershire borders .
Auto Sleeper Kemerton.
Im a newbie
The fuel is the same. But additives are added according to which retailer it goes to and which pumps its distributed by.
They do of course have to sell at ultra competitive prices which why they sell the cheapest blend to the tightest people.
Anyone who has the later common rail type diesels especially those with DPF filters are completely and utterly missing the point by using the basic cheap fuels.
Of course so many will argue to the contrary and it's thier cars so I couldn't give a monkeys.
You will get slightly better MPG but that's not the real point it's the cleaner burn that keeps the engine internals clean and your filters clear that matters.
I'm saying Nuffink more Nuffink not a jot or diddly squat Nuffink. Nowt... Bugger all.
It's all been said time and time again anyway.
denisejoe
5,630
12,106
Warden isle of sheppy
Morrisons is cheapest followed asda who adjust prices down to match tesco last always 2p dearer if not more
Thats in my area can't say other places
Joe
Oct 3, 2014
319
886
Llanelli, Wales
Rapido 891F A Class
Since 2014
I run a Toyota 1.4 diesel and have done various tests between super market diesel and well known brands I find that the car runs much better on Esso diesel and can give up to 6 mpg gallon.
Richard
DuxDeluxe
14,668
72,983
Planet Zog
A woosh bang van
You are absolutely right and Sorry, no I can't. Explained it all many times before to people who think they know better (as you know (y)) both here and elsewhere. Now I have retired from the fuel testing and quality business I really don't need the hassle. Perhaps I should have kept the page long explanation on a clipboard somewhere..........
Cheers and thanks for the mention (y)
Charlie
3,211
3,639
Im a newbie
I'm saying Nuffink...........
MC 55 FUN
3,432
6,347
2015 Majestic 195
Richard
The very same unadulterated fuel that is dispensed from the very same 6 or 7 U.K. refineries . . . . ?
Aug 18, 2014
23,857
134,487
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
Richard
It's the Tiger that helps.(y):D2
EX51SSS
6,073
28,561
North Manchester
Hymer Exsis A Class
since 2007
I've run our Moho for many trips and here I used Asda and in France I usually use L'eclerc. I've always been happy at the mpg.. However, over the years I've seen these suggestions that it's not as good as other fuels and last year, a Moho owner convinced me to try a 'decent' fuel and furthermore as I was going into Luxembourg then fill up on Premium quality and it'll clean your engine
Ok, apparently it's like an internal valet.
So, fuelled up with Premium and ran round and before I left Luxembourg, I topped up again to ensure the 'quality' fuel. I'm pretty fastidious at doing my mpg and so when I got home, I filled up with Asda and later did my calculations.
OMG!!!! How is that good. I was at least 20% worse mpg than with the fuel from supermarkets.
From now on its back to Asda here and local supermarket fuel when abroad. I'm just hoping that my mpg reverts to the standard I attained before.
No more Premium quality for me. What an absolute waste of money.
Don Quixote
2,966
5,259
Lost in La Mancha, Spain
VW T6 Campervan
At the end of the day what I put in my MH/Car is my choice and likewise what you do with yours is up to you.
Supermarket fuel sells and appears not to be a problem - likewise top end fuel sells maybe not as much as supermarket, but it does.............. so who wins?????? the man taking our money!
