Strange leisure battery problem any advice please (1 Viewer)
Mohomac
5
matlock
since 2016
When im on leisure battery power and have lounge lights on if I turn on the bathroom light or the outside light on the lounge lights go off..everything works fine on the engine battery. Ive checked leisure voltage and its 14v is there anything I should check? ps I have a solar panel fitted
11,851
14,093
Your leisure battery will only give a 14v reading if its on charge and that represents the charger voltage. Try measuring it at night with no ehu after its had an hour or so to settle down. You may have a duff battery.
M
Mohomac
5
matlock
since 2016
the battery is 6 months old and I tested it without ehu. its has a solar panel connected maybe I should disconect the battery and check the voltage again thanks for your reply
M
Mohomac
5
matlock
since 2016
Ive checked connections ill disconnect ...test and reconnect why do the lounge lights go out when the bathroom light and the outside light is turned on? I heard thats what happens when the battery is low is that true?
andy63
4,672
15,018
south shields
since 1990
Hi.. what sort of lights ie led ?? has it always done that or is it something that's just started... it does sound odd that all works off the start battery.
I was going to suggest a wiring fault but if it works fine off the start that's unlikely...
Can you get a meter on the light fitting to see what is happening voltage wise at the light fitting when it goes out..?Andy
JimJams
249
377
East Sussex / Kent
RV, A Class
since 2003
with a multimeter james
I would get your battery tested first by a battery specialist. As it is six months old then hopefully you will have a warranty.
Reading a voltage on a multimeter unfortunately wont give you the correct information on whether a cell has failed on a battery etc.. So many electrical problems in motorhomes or caravans doing different things all stem from potentially a faulty under performing battery. This would be the first thing to test and then go from there honestly.
two
Aug 4, 2011
4,906
4,578
West Midlands
A-Class Fiat
If the same circuit works with on battery but not another. It's the other battery that's at fault. May it has been left discharged over winter? It's not difficult to kill a battery by fully discharging. Check the battery.
JimJams
249
377
East Sussex / Kent
RV, A Class
since 2003
Also just to add when you have the battery tested make sure it is completely disconnected or an incorrect reading will be given
11,958
16,575
Before doing any further testing of the leisure battery see if the same thing happens on EHU. EHU will work all the leisure services whether a leisure battery is fitted or not (and whether it's up to scratch or not). If the same problem occurs on EHU then it is not a leisure battery problem.
JimJams
249
377
East Sussex / Kent
RV, A Class
since 2003
that's not quite right.. he has also tested it by selecting the power to be drawn off his engine battery and all works fine which generally would assume the leisure battery is to fault. when plugged into mains supply the battery is being supported by the mains charger so that wont diagnose anything..
M
Mohomac
5
matlock
since 2016
Thankyou for your replies. I have taken the leisure battery off and it reads 13.5v Ive checked the solar panel output it reads 16.4v into the box and same going out to leisure battery.Its on trickle charge now. re led lights they are in the lounge area but in the bathroom and the outside light are standard bulbs.It quite possible the leisure could have discharged but I did check it regularly and it was connected to the solar. lets see what happens Ill update if I get it cured incase anyone else gets the same problem.thanks
maxi77
892
560
Kingdom of Fife
coacbuilt
newbie
It sounds like a connection problem, some where you have a poor connection which will carry the power for your lounge lights, but not for all the lights. These problems can be hard to find, once I found a part blown fuse causing something similar.
