SPRINTER EGR VALVE (3 Viewers)
Middy42
248
69
Fleetwood
Since the 70s
Morning all, has anyone had to fit a new EGR VALVE to a 2.2 Sprinter. Barrie
Middy42
Middy42
248
69
Fleetwood
Since the 70s
Thanks for your help Bartiny, have bought a new one. £332 ouch. Barrie
DanielFord
3,020
3,086
My god they are expensive for a Merc, I just did a search to see if I could do better, and I can't!
rolandrat
436
258
Lancashire
Hi Top
Barrie, have you had to replace the EGR valve because of high mileage or lack of use or is it a known design fault?
Middy42
Middy42
248
69
Fleetwood
Since the 70s
Hi Roland, lack of use 6months, recovering from heart bypass. Barrie
ambulancekidd
Sep 23, 2014
10,372
28,401
Ayrshire Scotland
Swift Kon-Tiki 640
Hi, what age is your Motorhome Barrie? I have a 2006 model which was the new model then but still uses the 2148cc 4cylinder engine & its forever going into limp mode. A real shame because other than this issue its a beautiful vehicle to own & drive!
Robert.
RS_rob
1,010
669
Turnford
Robert.
Unscrew the wastegate valve a turn or two to reduce turbo pressure.
Wickolad
490
542
Wickersley
bin it & blank it...........................
That's what I've done having seen a few posts on here particularly the very descriptive post by techno100. I no longer have to worry about EGR failing or tripping into limp mode.
RS_rob
1,010
669
Turnford
VW & Merc are made in the same factory
they have high tolerances in the turbo system such that they are so close that one signal can overlap another hence on full boost the ECU can receive a signal for overboost & shut down i.e go into limp mode.
I looked this up on so many occasions having run a VW club & the cure was to lower the wastegate pressure setting i.e unscrew it a turn or two..
Its comon on VW T5's & later LT's those with the PD (Pump Deuse) Engines.
T4's r fine & I maxed mine out 153.3BHP 284.4NM Torque from a 88BHP engine. its all the sensors that are a pain...................
OldAgeTravellers
1,207
1,387
Telford, UK
Since 1970
I have a Sprinter and luckily never gone into Limp mode except when I forget to release the magnetic braking and accelerate. Where is the "Wastgate Valve"
Steve
Middy42
Middy42
248
69
Fleetwood
Since the 70s
Got a new one fitted at my local garage today £355 including vat. Happy now.
