split charge to 2x leasure batteries (1 Viewer)
Wild Oggie
71
109
cheshire
Bessacarr E462
Mid 70's
Hi,
I have 1x 110amp leasure battery being charged by a 30amp split charge relay connected to the van battery, protected by 2x20 amp fuses with 30amp wire.
Recently changed fridges to a waeco 12v version and want to add another 110amp leasure battery in parallel
Would I need to upgrade the relay, or would the present one do the job ok
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Was a newbie, now a Middie.
Hi,
I have six leisure and one engine starter battery on our narrowboat. They all work fine through the one split charge relay. The relay is passing current in one direction only, namely from the alternator, the maximum output of which is unaffected by the number of batteries you have on.
43,334
49,533
Converters use a 30amp relay as they are the commonest and most readily available one there is.
Your alternator will never put 30 amps through the relay.
Al1
49
19
Even with 2 flat 110A batteries? Asking as I have mine wired with 3mm2 cable and was worried that it was undersized. If I can add a second battery then it would be ideal.
Al
