split charge to 2x leasure batteries
Discussion in 'Tech/Mech General' started by oggie, Aug 26, 2014.
  1. oggie
    oggie Read Only Funster
    Mar 25, 2014
    30
    34
    cheshire
    Hi,
    I have 1x 110amp leasure battery being charged by a 30amp split charge relay connected to the van battery, protected by 2x20 amp fuses with 30amp wire.
    Recently changed fridges to a waeco 12v version and want to add another 110amp leasure battery in parallel
    Would I need to upgrade the relay, or would the present one do the job ok
    • Like it Like it x 1
  2. scotjimland
    Jul 25, 2007
    28,938
    25,625
    As you are adding storage capacity, not increasing the charging current, the relay doesn't need changing
    • Like it Like it x 2
  3. Tootles
    Tootles Funster
    Sep 14, 2013
    9,251
    33,130
    Lancaster
    I have six leisure and one engine starter battery on our narrowboat. They all work fine through the one split charge relay. The relay is passing current in one direction only, namely from the alternator, the maximum output of which is unaffected by the number of batteries you have on.
  4. oggie
    Mar 25, 2014
    30
    34
    cheshire
    Thanks guys, thats brilliant
  5. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,096
    17,764
    YO11 2BD
    Converters use a 30amp relay as they are the commonest and most readily available one there is.
    Your alternator will never put 30 amps through the relay.
  6. Al1
    Al1 Read Only Funster
    Jul 20, 2008
    37
    10
    Even with 2 flat 110A batteries? Asking as I have mine wired with 3mm2 cable and was worried that it was undersized. If I can add a second battery then it would be ideal.
    Al
