Spanish Aires POI
Discussion in 'Spain' started by Judge Mental, Dec 12, 2014.
  1. Judge Mental
    Judge Mental Funster Deceased RIP
    Sep 2, 2009
    6,782
    6,038
    Sarth London
    A helpful person added the following link to a thread recently. there is an orange button on page showing a gps unit. I have downloaded the file which I presume is zipped. Can anyone who is a bit techy help, and advise how i can turn this useful resource into a Garmin file...we live in hope!:)
    http://www.areasac.es/v_portal/apartados/apartado.asp?te=4
  2. MikeandCarolyn
    MikeandCarolyn Read Only Funster
    Mar 18, 2008
    2,171
    1,463
    Worle,North Somerset
    Looks like you need to convert the .rar files you've downloaded to .csv for the Garmin :xThumb:
    Hopefully someone with a bit more knowledge will be along soon.
    • Like it Like it x 1
  3. TheCaller
    TheCaller Funster
    Sep 23, 2013
    2,010
    2,361
    Lincs
    You are correct, it is a compressed file, in rar format rather than zip. The file contains the POIs in the correct formats for a whole range of different Sat Navs.
    I'll send you a 'Conversation' with the Garmin file attached.
    What model do you have? There is one file labelled for Navman_Garmin & another that says Garmin_GPX. Both files have the .gpx extension. They appear identical apart from a slight difference in the way the date & time is recorded against each record. I don't know what the date & time mean, unless it's the time the record was added to the database, because it's the same on every record.
    <time>2014-04-07T18:22:42.000Z</time> for the Garmin_GPX
    <time>2014-04-07T18:22:42.921Z</time> for the Navman_Garmin
    There is a master .csv file which just has the date in this format:
    07/04/2014 20:22:42
    There is also a PDF file with the full listing in printable form.
  4. Judge Mental
    Sep 2, 2009
    6,782
    6,038
    Sarth London
    blimey..Thanks! Garmin Nuvi 2547 LM?
  5. TheCaller
    TheCaller Funster
    Sep 23, 2013
    2,010
    2,361
    Lincs
    Ok. Have send the straight Garmin one.
  6. MikeandCarolyn
    Mar 18, 2008
    2,171
    1,463
    Following on from this,I've just found that Garmin do a piece of software called Garmin POI Loader.One of it's functions seems to be to enable the setting of proximity alerts for custom POI's.
    I found this function invaluable on my first Navman-I put on 'all the aires France' then an alert would 'pop up' saying 'Aire in 1km'.
    When I changed to Garmin (it was all Halfords in Dover had when the Navman died suddenly) I missed that function.Garmin Support told me no one wanted it,so it wasn't there.
    I shall investigate further,or,if anyone knows anything about setting alerts on a Garmin,let's hear from you.:xThumb:
