Some Useful Computer Advice (1 Viewer)
Aug 14, 2007
526
104
Devizes
Mobilvetta K-Yacht 80
Hi All,
Had some problems with one of my important software packages last week and ended up having to turn the computer back to factory settings.
In the process of this I had some technical assistance that if you are not aware of it, may be of help.
Basically if you have a problem and don't know what is causing it you can go through this procedure which uses what we used to call the split half technique.
Click Here
Hope this helps someone out there.
Best regards
Chris
Jim
Ringleader
Jul 19, 2007
36,438
130,977
Sutton on Sea, UK
Adria Panel Van.
Since 1988
Could I add, that the best thing to do is when your computer is whizzing along and behaving well is use Acronis to take an image of the disk.
If anything goes wrong, or when your PC starts slowing up like they do, you can simply install the image and in a few minutes and you are back to where you started. Its a great bit of software that has saved my bacon a few times.
You can download a Link Removed(affiliate link) orLink Removed
G2EWS
Aug 14, 2007
526
104
Devizes
HI Jim,
Absolutely agree with that. Indeed the Lenovo Thinkpad comes with a button called 'Thinkvantage' which when you press it amongst other things brings up a 'Rescue & Recovery' section that allows you to take a copy of your hard drive as is.
All the way through installing software I kept taking images, just in case!
Best regards
Chris
In the process of this I had some technical assistance that if you are not aware of it, may be of help. Chris
That is much better than safe mode - thanks.
I notice you list RC Helicopters.
I don't like failure but by god I've failed with this. I bought a mickey mouse contra rotor thing, bit of fun, so lets go further.
Oh boy.
Bought an ESky Honey Bee. Dismal failure. I've never seen bad go worse so quickly like this can. Indoors I've managed a whole two or three seconds hover before it wants to axe the furniture. Outdoors a bit longer but a lawn is very unforgiving for a helicopter flying sideways. I used a large cardboard for take off but a breath of wind and there's no way back for me. It's running costs maybe on a par with the real thing in terms of ££££ per hour flown.
I must pluck up courage for another go.
S
sinbad1
i'm with jim here would highly recomend acronis do full backups/ incremental backups you can mount images as if they are drives and copy over any part, even clone your drive to another drive for replacement.
Great software, as Jim says you can get a working trial version or you can purchase
for around £25
G2EWS
Aug 14, 2007
526
104
Devizes
Oh boy.
Hi Brian,
Before you go any further you need to buy this:
It allows you to use your own controller and fly the same helicopter but on the computer and not in real life.
I have a contra rotating HC and once I used this software the helicopter became to easy to use. Bearing in mind you cannot use it outside even if there is a breath of wind.
I moved onto bigger better things and found them difficult to start with but once you get used to them, great fun.
Not had much chance to mess around lately. Photography has taken over my spare time!
Regards
Chris
Hi Brian, Before you go any further you need to buy this:
Chris
I bought the one by ESky. It must be reasonable because I have many of the same crashes on the PC :)
I'll keep my fingers crossed for some better weather this year and my daughter has a new house with a big field I might do better there.
I have to agree, UK weather suits photography much more than any form of flying.
American Dream
156
Lincoln
Off Topic I know , But one of my friends made a fair living by taking aerial photos from a rather large RC Helicopter.
Brilliant shots too.
msconfig is one of the most widely used diagnostic tools available for troubleshooting.
Goes much further than just Safe mode startup.:thumb:
Normal one or that oddball 4 rotor German one like a flying saucer ? Now that is an incredible beastie...
http://www.barnardmicrosystems.com/L4E_quadnews.htm
American Dream
156
Lincoln
This was a "Normal" one........:Eeek:
Crikey That's wierd....Ok until one prop or drive fails.....:RollEyes::ROFLMAO::ROFLMAO::ROFLMAO:
Now ....Back on topic...:ROFLMAO:That wouldn't be flying in SAFE mode...:RollEyes:
