Solar Panel Information and Help (2 Viewers)
Gloombusters
91
32
West Sussex
Swift Bessacarr 454
30+ years
Whilst sitting here in the driving rain at El Berro, I thought it might be a good opportunity to pick a few Funsters brains.
We are spending more time these days being more adventurous and seeking out Aires in more remote areas and so far it's been very successful and we hope to continue.
Before we set off on our travels we had the Gaslow system installed which to date has been great (and cheap to fill). So that was the gas problem out of the way and no more empty Calor bottles to deal with! We can just about survive for three/four days on the leisure battery before the wonderful (not) Elddis blown air heater packs up because it detects low 12v to the fan. The pump begins to die and the tele goes off. UGH! It's not fair on other campers to run the engine up either. So after all this I think we need a solar panel to assist. I'm sure there's a lot of Funsters with vast experience and knowledge of Solar panels ie what to avoid,what ones are best etc. I'm basically looking for a fixed roof panel that will assist the 12v system for 4/5 days of good reliability and quality that will do the job. I'd rather spend a few extra bob than buy a cheapo! It will be the first job I'll have done when I return th the UK. Any advice really appreciated. HAPPY TRAVELS.
18,033
48,139
There isn't a huge difference between panels but controllers vary. The best are MPPT types. I fitted a Victron one which are well reviewed. Finding a reliable installer might be your main challenge if not fitting yourself.
andy63
4,672
15,018
south shields
since 1990
Hi.. try and work out what your approx usage is per day in amp hours... When you know that I'm sure someone will be able to advise on what solar capacity would be capable of replacing your daily usage... will depend on whether you are in UK or sunny climbs... everyone's usage is different and that's the hard part..
Doing what you are doing now will shorten the life of your batteries..It's better to keep them charged up or charged as soon as possible after use..
Andy
18,033
48,139
My original panel was 100W and this was fine until we got a compressor cool box so I have recently fitted a second one 100W panel but it hasn't been used in anger yet.
There was a time when 80W was considered enough but now 120W might be considered the minimum and some have considerably more especially if they have a large inverter for running things like microwaves. How much you need really is a piece of string question but if you want to use the vehicle in winter when light levels are low then the more the better!
Armytwowheels
6,475
14,881
Market Harborough
Carthago S Plus - Iveco
Since 2011
Good morning @Gloombusters .
If you want to mosey on down to the Camperstop near Totana for a coffee and Solar Panel chat you would be welcome. Colin fitted ours and has a good understanding of what you will need based on usual usage etc.
We are off out shopping today but will be here for at least another week.
eddie
8,159
41,279
Taunton Somerset
RV
since 1989
As a rule of thumb, for most people, if they can survive say three days off electric with a single 12 volt battery without a solar panel, a decent solar set up 100 watts with a good quality MPPT regulator will sort them out
Again the rule of thumb I try to use is that the applies, on average, for the 2nd half of Spring, the Summer, and the 1st half of the Autumn, in a use and expect replenished scenario
The 2nd half of Autumn, the Winter and the 1st half of Spring, it is more maintenance to the engine and leisure battery, rather than use and replinish
Obviously if your abroad, you need to adapt this to suit the weather lol
Bear in mind though at the NEC show in February, a argumentative chap was the talk of the trade as he was going round telling anyone selling solar that he was self sufficient 365 in the UK with a 50 watt panel and a compressor fridge, which simply isn't possible o_O
Solar is good, but it is not that good(y)
R
Robert Clark
Hi Eddie
Can you quantify what an 'average' user may consume in a day, and if this is via an inverter, or just on 12v
Would this include for example, hair dryers and coffee pod machines?
Robert
eddie
8,159
41,279
Taunton Somerset
RV
since 1989
Hi Eddie
Robert
lol Average would be a bog standard medium sized motorhome with one 110Ah battery, being used by a couple who think that they are being "adventurous" going to a three day rally without hook up lol
I wouldn't class you or yours as "average" Robert (y)
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Think he was looking for Numbers Eddie not an opinion:LOL:
G
Throw 100W on top and give it a go, you know by now what happens on low volts, in other words you don't die instantly.
Under ÂŁ200 if you DIY. It's all documented on here in great detail.
andy63
4,672
15,018
south shields
since 1990
It is a hard one to quantify...
My van is small self build but it has diesel heating and hot water..
A small 65l compressor fridge.. telly which gets little use ,and then there's the need to charge phones tablets etc on up to 2 amp usb sockets.. All lighting is led but each one comes in at around 200 /300 ma... It all adds up..It's not unusual for me to be 35amp hours in deficit in a day.. my battery bank is 2x 110 ah batteries and if I don't charge them I'm lasting 2 to 3 days . That's why I carry a Genny. ..:) no inverter with my set up... Just not practical..
I only have room for a 100w panel and it's just not enough to keep me self sufficient.. It will run the fridge in the summer if it's good that's it..
Andy.
Reactions: DBK
Jan 28, 2008
10,117
18,383
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
the problem with mppt controllers is the cost a good mppt will gain you 30 percent more power, a second panel will gain 100 percent last time i looked the panel cost less than the mppt so unless your short of space a second panel is more bang per buck
in the op's case a second battery would probably cure the problems but a second battery and some solar panels definitely will especially in summer
Kool Kroozer
1,361
2,228
Cannock Staffordshire
Low Profile Hobby Premium
Always learning
You can save yourself a tidy penny if fitting yourself, i recently fitted x2 140w panels and x2 125ah leisure batteries all for less than ÂŁ400, inc cable, cleaner, sikaflex, controller... saved myself a packet, and at least you get some satisfaction out of it by doing it yourself - its not the main reason why i fitted mine to be completley honest, the main reason is i have seen workshop jobs and i know i can do a better job myself, all the cables are tied down and in the right places - thats another story though.
32,667
66,624
Totally agree, when I was putting a solar panel on our new PVC last May the cost difference between a standard and an MPPT controller was ridiculous - to get a standard one was ÂŁ62, an MPPT one was more than double the cost at nearly ÂŁ140!
We tend to charge up mobiles/sat nav, laptop etc during the day, watch TV for an hour on a night, and use lights on an evening. We have gas heating/hot water and a standard 3-way fridge which again we power with the gas.
Our previous PVC had a 75w standard type panel on that was a good few years old (plus 2 leisure batteries) and never had any issues with low battery power. On our new van I fitted a 60w semi-flexible panel (got it really cheap from a show!) to go with the 2 leisure batteries (part of the deal) and we are seeing how we go with this set-up but so far we've not had any issues with batteries being low despite always using aires or 'wilding' and having 6 week holidays. If we start to get short of power the first thing I would do is fit another panel to give me 100% more power ... or more if I decided to fit a bigger one!
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Quality 200watt mppt ÂŁ75 or less ÂŁ10 more for 300watt
Easy to say bang another panel on but you have to consider both space and weight.
If you can bang another on then there's another 25% for that too
Techno
Jul 28, 2010
15,475
20,756
May 2010
22.5 amps achieved
32,667
66,624
Agree Andy but for with my fitted Schaudt electroblock, it has to be either an LR1218 or and LRM1218 controller ... especially to ensure that some of the input goes to keep the engine battery charged up too.
Andy, with my Schaudt set-up what would you have done? If I was starting from scratch except for the 60w panel, how would you install it to get the best out of it? This isn't mischief making, it's a genuine question in case I need/want to add to it in the future. I have a fair bit of roof space left so fitting another panel isn't a problem.
Techno
Jul 28, 2010
15,475
20,756
May 2010
Is yours one of the electroblocs that MUST use a schaudt regulator? not all do.
32,667
66,624
Unfortunately yes ... :(
It's an EBL99k
Techno
Jul 28, 2010
15,475
20,756
May 2010
You have no option then
A&N caravan services are fairly good on EBL info BUT not entirely correct so always best to check directly with UDO LANG
A&N list the 226 as one that must use a schaudt regulator but my direct contact with UDO refuted that.
Fitting 300 watt on @Drexxer s van meant exceeding the capability of the electrobloc so would not be possible. UDO confirmed that the MPPT I use was OK direct to the batteries
Jan 28, 2008
10,117
18,383
Renalt burstner
i rest my case
Jan 28, 2008
10,117
18,383
Renalt burstner
80 watts is 80 watts just the panels are a little bit larger you right about the weight though that panel is 5 bottles of wine
Techno
Jul 28, 2010
15,475
20,756
May 2010
Poly is a poor choice for UK as it needs SUN rather than just bright that mono will still produce in.
32,667
66,624
Any good?
Techno
Jul 28, 2010
15,475
20,756
May 2010
I have no experience of flexi panels but I would not use them myself I prefer glass and a frame
32,667
66,624
I researched them a fair bit before I stuck mine on, both talking to suppliers who sold both types and also on the web etc - I could have sold it and bought a glass one instead but by the time I'd added brackets etc to mount one there wouldn't have been any benefit, plus the flexi one is more 'forgiving' to any flexing etc and is supposed to wear well - apparently you can walk on them which is why they are popular with the boating fraternity.
I was more interested in your comment ref using mono rather than poly ones.
