Solar fuse ...remove or not? (3 Viewers)
Dec 4, 2012
1,070
1,296
leicester
swift kontiki and vw cam
15yrs
I need to top up my leisure battery and was wondering if this can be done whilst the solar is still functioning. I have two batteries one is sealed and I am ashamed to say that after owning the van for over two years now I have just discovered that the one under the passenger seat needs maintenance!! (probably too late but worth a try) There is a small flat fuse near the solar control panel ...... should I remove that before topping up?
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
You don't need to remove the fuse when topping up, only if disconnecting the batteries. I assume the fuse is between the solar panel and the solar regulator/controller so that it can be used to isolate the panel from the regulator.
17,635
43,372
so long as the solar controller has a load for its current (battery) attached it should be fine. i prefer not to open and top up batteries as they are being charged, as there is a risk of them bubbling and gassing off if the battery is faulty. however if you take precautions like eye protection it should be fine. just dont over fill and splash
ambulancekidd
Sep 23, 2014
10,373
28,401
Ayrshire Scotland
Swift Kon-Tiki 640
I'd be happier removing the fuse as you don't want a stray spark around batteries when your topping up.
Lucky one
Dec 4, 2012
1,070
1,296
leicester
15yrs
Yes it is before the wire gets to the batteries. I had been looking to replacing the batteries as i have not been getting very good output and now I know why lol.... Fingers crossed that a few pence worth of distilled water will produce a miracle cure ....
17,635
43,372
it is unlikely a top up will recover a neglected battery. whilst the seat is off, i would renew the battery with a lead calcium sealed battery
Lucky one
Dec 4, 2012
1,070
1,296
leicester
15yrs
Think i will remove fuse to be on safe side . .. thankyou all for quick replies.
Yes TheBig1 it is a long shot but worth a try ....haven't got seat off yet... It can be accessed by sliding seat forward
JeanLuc
3,304
2,199
Warwickshire
You need a fuse (or switch) in the positive cable between the solar panel and the solar regulator/controller if you want to use it to disconnect the feed from the panel. If the fuse is between the regulator and the batteries this will not isolate the panel. Your installation will probably require a fuse between regulator and batteries as you have described, but do not pull this one out if the panel is still connected to the regulator and this can cause damage to the regulator. One option is to get on the roof and cover the panel with a blanket before pulling the fuse or disconnecting the batteries in any way.
Lucky one
Dec 4, 2012
1,070
1,296
leicester
15yrs
itI think I may have mislead you jeanluc when I said it was before the battery so I have taken photo and hopefully you can see it lol
