'SOG' what is it? (1 Viewer)
Ann&MikeMancs
Oct 25, 2014
124
72
Salford
Carthago Chic 5.0i
Will do. Many thanks (will try to find how to search lol)
Ann
13,087
101,483
Bolsover, Derbyshire
Hymer S800
not long enough
It is a weird device that sucks air from the cassette when the blade is opened, sounds good in principle not so sure in practice
We had one on last van
The air has to be taken out from the top of the cassette, so there is something else to fiddle with when emptying cassette
We also suffered the ultimate price, not sure that ours was properly fitted, but drove with full cassette and ended up with brown streaks down side of MH as contents tried to escape through air vent
Another gimmick I would not pay for if not already fitted (y)
43,332
49,517
To save asearch........a SOG is a basic 12v fan which extracts fumes from your cassette, passes the fumes through a carbon filter and sends it merrily on its way to the great outdoors.
Works well but the contents of the cassette dont get chance to decompose and stink to high heaven when you empty out.
It negates the need for chemicals so can be emptied in any kind of sewer drain....chemicals should never be emptied into a septic tank system as the chems kill the good bacteria.
18,033
48,139
SOGs are brilliant things that enable you to avoid using Earth-destroying chemicals. Also a great topic of conversation here: http://www.motorhomefun.co.uk/forum/threads/sog-toilet-emptying-bio-hazard.95904/page-4
You will be left in the cold if you don't have one. :) Put one on your Christmas list.
Rumours that the manufacturer is bringing out a turbo version to deal with constipation are I think just wishful thinking - unfortunately.
Jim
Ringleader
Jul 19, 2007
36,446
131,004
Sutton on Sea, UK
Adria Panel Van.
Since 1988
Never felt the need for a Sog, depends how you use your loo. If you want to open the valve and plop straight into the tank then it might help. I'd rather plop into a bit of water, then close the lid and activate the valve, No smells at all, maybe mine doesn't smell. :)
5,545
18,775
Mobilvetta Euroyacht
1996, then break 'til 2011
? Too much information ?
eddie
8,159
41,279
Taunton Somerset
RV
since 1989
SOG is great to let the whole world that your using the loo! You flush, and when the pump is running, it turns on a fan, thus pulls air from inside the motorhome, down trough the toilet, down into the poo tank, across the wee and poo, and pumps it outside, over the next doors dinner table (if your loo is on the drivers side) and out under you awning if you loo is on the caravans door side!
You take a perfectly good Thetford toilet, drill holes into it, bodge into the wiring and cut a hole in the door, just to stink the high heavens out when you empty it, and stink out your awning or next doors dinner every time you have a wee (do use if your easyily embarrassed lol) oh yes and the simple slide in action of the cassette, is compromised as you have to hook up and disconnect the fan to the tank every "in and out" action.
Formaldehyde by the way can be used in chemical treatment plants, we didn't think it could be when we built our camp site and had special tanks installed for chemical toilets. Only to find that the problem is the high concentration of solids in cassettes and holding tanks that can cause treatment plants problems rather than the formaldehyde.
Of course none of that is a problem with a SOG as you never get chance to build up solids as the smell is so bad you have to empty it every day ::bigsmile:
I guess that's why Thetford don't add it as standard!
Chris
21,056
278,984
10 years
Well after that, I really must get one!
T
Tackle man
My Thetford loo has none of the "bodging" you speak of. The SOG is built in at the factory. The only evidence that it exists apart from the carbon filter in the cassette chamber slot is a button on the flush panel in the loo. this gives the user the choice of using SOG or not. In modern units the thetford cassettes are greatly reduced in size anyway and need emptying more frequently. (everyday if not on main sites) so the contents don't have chance to break down. Another reason to empty the smaller cassettes each day is to allow for the possibility of overnight illness that can occur. We all have times when things upset us down below and it is a comforting thought to think the loo can take it when needed.
I do add a little bio washing machine liquid from Lidl each day through choice.
eddie
8,159
41,279
Taunton Somerset
RV
since 1989
Are you sure you have a SOG? Thetford do the C250 electric ventilator kit. This is what is normally used if your system is factory fitted.
Presumably to combat the smell of poo rotting down? ;)
eddie
8,159
41,279
Taunton Somerset
RV
since 1989
SOG is a system which does away with chemicals altogether. It uses bacteria to break down solids. We have one, and yesterday I contacted SOG who said dont use chemicals.
Phil
Which is of course why it smells so bad when you flush and empty your cassette ;)
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
The benefit of not using chemicals IS that you don't have to wait for it to be full to empty it as there is no expense. Personally I much prefer to empty it everyday before it gets heavy I don't see that as a handicap.
In our experience it does not smell outside, that is usually down to not renewing the filter.
T
Tackle man
Quite possibly have a C250 unit. I stand corrected if that is the case. The reason I put the Bio in the tank is to to mask the smell when emptying. I'd rather smell the Bio than the other proprietory brands .
Judge Mental
Sep 2, 2009
6,650
5,883
Sarth London
Possl 636 FR panel van
1994 and beyond...
I would not have a van without one. have a look at your soil stack on your house..it is vented to the air. if you dont have a SOG when you open the trap contents are venting into the van..how disgusting is that! no matter how nasty or sweet smelling the chemicals you use.
plus you can empty into a toilet with a clean conscience.
11,843
14,076
The SOG has a carbon filter to reduce the pong blown out when used. These do need replacing periodically and I think a lot of users don't to go by the niff of some of them.
I use bio liquid which removes the pong and is so cheap it isn't expensive to empty daily, which I always do if an emptying point is available. This also has the advantage that the cassette isn't so heavy if the emptying point is not too near. (and I prefer it not too near if people are emptying SOG cassettes :reel:)
