gerry mcg
It would be interesting to see a feature comparison between the Snipe 2 and Snipe 3 models, assuming the latter is a reality.I had heard whisper tell of the release of Snipe 3 satellite system but have yet to see it advertised. Have you got a link to any of these adverts?
..the H3 Ducato PVC chassis is 2.75m tall and i need to keep it under 3m (when folded) for keeping within Class 2 on the Autoroutes in France.
Sika 252 with the Aktivator 206 and I think for your roof the 206 G+P primer, the 252 is a structural Adhesive and needs to be applied at 7-8mm and when compressed should be 4-5mm (use spacers to achieve) thick so maybe fill in the corrugated parts (extra tube for £25) with adhesive so you have a continuous bed of adhesiveYip, aware of the corrugations. My thinking was a suitable Sikaflex adhesive only on the raised elements of the roof to attach the baseplate only with no bolts / fixings going through the roof.
I'm guessing that using raised elements only for adhesive would give me say 50% baseplate area coverage, which is probably sufficient
The twin LNB also allows you to have 2 tv’s watching different programsI'm like the order a Snipe v3 when I get back from holiday.
They do a single and thin LNB version. What is the benefit of a twin LNB? I assume the twin LMB allows recording of a second channel. Not something I'm bothered about TBH.
