Smev gas hob ignition (2 Viewers)
Oct 17, 2014
102
123
London
Possl Roadcruiser PVC
Since 2011
Wee have a 2 burner Smev hob in our Possl. One burner works just fine, but the other is temperamental - sometimes ignites ok, sometimes won't stay alight at all. Gas supply is ok so it must be a problem with the cut-out thing that pokes into the flame (excuse technical description :) ) I guess.
Any ideas welcome - maybe the 'thing' needs replacing?
Hughman
Oct 17, 2014
102
123
London
Since 2011
'We', not 'Wee', of course - don't know how to edit post :(
Sep 10, 2012
2,133
3,714
worcester
Sunliving van
The thing is called a thermo couple, the job of which is to cut the gas supply if no heat from a flame.
Ours plays up from time to time but if you keep the knob depressed for longer than usual when lighting it seems to work ok after. Until the next time
Feb 9, 2008
8,951
18,708
Corby, Northants
Coach Built
Have a similar problem with my Grill, will not stay alight for more than 20 seconds and convinced it's the thermal couple. Solution, simple's we don't use it.
2,337
10,145
as said..
make sure the tip of the thermocouple is in the hot part of the flame.. ie the blue tip..
also check that the other end the TC for tightness...
If it still 'plays up' it may need a new thermocouple
Feb 9, 2008
8,951
18,708
Corby, Northants
Coach Built
Thanks! Yes that's my conclusion too but would need to remove oven and I'm neither competent or qualified to do this work and happy to leave well alone. And, i'm not paying a load of cash just to have a simple screw out screw in done.
Think I'd get screwed myself LOL
gozomike
Funster Life Member
1,001
863
Warwickshire - sometimes - but not often
Wildax Constellation
Since August 2008
I had the same problem with a smev hob and had to hold the button in for some time. If it lights and then goes out when you release the button, or soon after, it sound like a thermal couple problem.
up4it
32
24
Kent
Motorhome
February 2011
I have had this with my burners I just pulled off the push on connections from the thermocouple where it connects to the bottom of the gas tap and pushed it back on again job done.
Gus
Debs
6,303
181,745
West Notts
A class Adria Vision
Can't help with the oven but if you want to edit just look along the bottom of your post - should give the option of 'edit' on the left hand side(y)
Hughman
Oct 17, 2014
102
123
London
Since 2011
Gus
I'll try that - always did like a cost-free solution :)
If it doesn't work, looks like a new thermocouple.
Hughman
Oct 17, 2014
102
123
London
Since 2011
Not on mine for some reason :(
Feb 9, 2008
8,951
18,708
Corby, Northants
Coach Built
Well Bugger me ! Had a look at YouTube and was advised to clean with glass paper and now it works! Must have got contaminated when roasting stuff in the oven. Need to find another little job now !
Debs
6,303
181,745
West Notts
Could be due to you be a read only, you only get a handful of posts to use?
If you pay the tenner to join you'll get access to the rest of the site.
Best money you'll spend, believe me:):)(y)
Dec 12, 2010
5,414
21,591
Cumbria
Our hob used to do that, like Gus said, just redo the push on connections to the burner control taps.
Judge Mental
Sep 2, 2009
6,650
5,883
Sarth London
Possl 636 FR panel van
1994 and beyond...
mine did likewise in Spain last year tried to fix it but not being very technical gave up and bought a new one..approx £150 I think
11,955
16,570
Thermocouples are generic & usually cost £7 - £15. The push-on connectors on the gas control are what triggers the spark. The thermocouple connection is rather like a pipe connection but is in fact electrical.
up4it
32
24
Kent
Motorhome
February 2011
The ignitor on mine is on a seperate switch, so that would make the one on the bottom of the gas control the thermocouple? and yes it is more like a pipe but still has a push on connector.
Gus
Hughman
Oct 17, 2014
102
123
London
Since 2011
Paid my tenner now - let's see what happens :)
