slideout awning repair.
Discussion in 'American RV's' started by zaskar, Nov 5, 2007.
  1. zaskar
    zaskar Funster
    Sep 25, 2007
    984
    95
    UK
    The slideout awning on my Landau has come apart at the front end over a length of about 24". It's not ripped, whats happened is that at the coach side awning rail (inner edge) of the awning, the material is doubled back on itself and bonded to form a loop for a 6mm plastic rod which is then fed into the rail.
    The bonding has come apart.
    What should I re-bond it with?
    Is there a propriatory glue?
    Linda? :)
  2. Road Runner
    Road Runner Read Only Funster
    Jul 26, 2007
    14,196
    1,459
    Europe
    Do a search for awning repairers.
    Theres loads of them out there mainly for caravans.
    Might be best long term solution.
  3. Lindy-C
    Lindy-C Deleted User
    There isn't as far as I know Paul.
    That said, it should be safe to use any adhesive designed for use on soft plastics - Evo-stick do one...inexpensive and effective. Alternatively try a sail repair adhesive.
  4. Tony Santara
    Tony Santara Funster
    Jul 26, 2007
    1,494
    114
    Cheshire (ex Mancunian)
    Hi Paul
    Powerbond is a good adhesive sticks anything to anything
    www.powerbondUK.com
  5. olley
    olley Funster
    Jul 29, 2007
    3,746
    2,189
    Ipswich
    Looks like super glue with fancy name.
    Olley
  6. Harley Dave
    Harley Dave Read Only Funster
    Oct 15, 2007
    61
    Overton, Hants
    I agree, it does look like super (duper) glue - seems it will stick fingers too!!
    Copied from their website
    Question 10 What would happen if I got it on my skin?
    Answer: The place most likely to come into contact with Powerbond, for obvious reasons, is your fingers. If you got it on your fingers simply rub them together in small circular motions, this renders the adhesive harmless and the resultant film can either be peeled off or washed off with warm soapy water. If you were to hold your fingers together and press for a few seconds then, yes, they would bond; this is nothing to be unduly concerned about however. Powerbond is supplied with a high performance Debonder, a glue remover, which can be used to free bonded fingers or unbond badly bonded items.
    Dave
