Skylight Parts (1 Viewer)
Fletton
1,531
2,501
Lincolnshire, UK
Knaus Sky I Plus 650LG
First MoHo - April 2015
I can only assume that this occurred when the skylight suddenly blew open in strong winds a week or so ago..
Last night the pivot pin came out when I opened the skylight just before retiring... and I can see that one end has snapped off...
Have any of you Guys n Gals relpaced these pins; i.e are they available?
Or am I looking for an alternative fix (pin) setup?..
Ta ;)
Tkly
132
125
Near Stonehenge
Self Build
9 Years
I would add two washers to that one either side and a nylok nut so it can be secured without being tight and bending the plastic
Fletton
Fletton
1,531
2,501
Lincolnshire, UK
I would just replace with a suitable nut & bolt, find a bolt with enough plain part so not rotating on thread.
@Manic that was my immediate thought ;) because if said pins exist they'll probably be a zillion quid each!.
xulih
100
800
58.89º North
Autocruise Accent
Newbie
Search ebay for plastic clevis pin.
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
Use either stainless or plastic - cold metal will attract condensation. If you can't obtain an OE part find a plastic knitting needle the same diameter. Knitting needles are an excellent source of plastic rod because they are available in many different diameters. Apparently they're quite useful for creating woollen garments too :D.
Aug 18, 2014
23,782
133,678
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
When I wanted some all the knitting needles I could find here were hollow ,thin wall steel tube :(
Abacist
3,734
10,702
Devon
N & B Arto 88F Tag
since 2013
A good Yacht chandlers should have the stainless
