Shower tray (3 Viewers)
Ambilkate
8,652
18,061
Shropshire
HYMER 654
since 2006
Just rang swift to find out if we can still order a shower tray for our 2006 sundance 630g which is a 2004 model. To be told we can only go through a dealer so we rang Salop Liesure who we bought it off told us it would be possibly June before they could get it in and the bad news was £1,200 +:whatthe::Eeek::Eeek::Eeek:
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
I know this is a bit of a trek, but Branfibre used to offer a motorhome shower tray repair service. They specialise in glass fibre and grp mouldings. I'm not sure if they are still in business as their website is no longer active but you could try a phone call.
Oct 28, 2013
490
443
Lincoln
Such a company could probably even make one for less than £1200, including creating a mould...
Feb 16, 2013
19,742
52,066
uttoxeter
ambulance conversion
50 years
Have a look at towtal website, they mend them and make a good job too, I have seen one , only in stoke ,opposite stoke City Britannia so not too far where ever you are in Shropshire :thumb:
Stephen & Jeannie
4,174
3,265
Gobowen near Oswestry !!
Sold and bought a Caravan
9 years !!!!
Give this guy a ring !!
J. P. Underhill 01568 611498 or 07508178995.:thumb:
He repaired mine as good as new and a sensible price ! he is based just short of Leominster !:Cool::Cool::Cool:
Ambilkate
Ambilkate
8,652
18,061
Shropshire
HYMER 654
since 2006
Thanks for the replys Hubbys on a mission now to get it sorted it thanks again
Feb 27, 2011
14,741
76,119
Or you could do what I did :Doh:
See image and it cost less than 10p. :ROFLMAO::ROFLMAO::ROFLMAO:
I am going to redo it though so it looks a bit neater without crease etc.
Ambilkate
Ambilkate
8,652
18,061
Shropshire
HYMER 654
since 2006
:ROFLMAO::ROFLMAO::ROFLMAO: thats cheered me up thanks. Its been taped up for a while now. Bill is on a mission to get it done. :Sad: I know it will cost more than 10p
17,637
43,375
you can plastic weld cracks using a soldering iron, a plastic rod and a dremel grinder. theres videos on youtube and its very easy to do
£1200 for a piece of plastic that maybe cost 50p to vacum form, its just ridiculous
Feb 27, 2011
14,741
76,119
More seriously. I have just bought a load of fibre glass mat and a resin mix. I will attempt a repair and will also reinforce all edges and the base while I am at it. If this fails I will buy a new tray.
I get mine from Magnums who as well as having a good range also have loads of stock from companies that have ceased trading. It may be worth contacting them to see if they have one. Get the measurements and give them a call you have nothing to lose.
This is the one I use and I cut it down to size.
Moodybrook
802
651
Wet and cold place outside of M25
4 wheels and a pointy end
still in nappies
Shower trays !
Wouldn't dream of putting the same crap in that was initial install.
I am in the throes of installing a domestic one, high density foam acrylic top, (Wickes £54) they only have low profile ones which means I would have a bit of juggling with meeting up with the previous fix lines.
Setting it on additional 3/4 exterior ply, just sorting the 3mm sheeting to clad the walls at the same time to get round the above problem of low profile and fix lines.
Can't envisage anything like £1200 !! more like £150. :Smile:
Ambilkate
Ambilkate
8,652
18,061
Shropshire
HYMER 654
since 2006
Anyone on fun actually done this and used a dremel grinder after interested in final finish. Bill is defo on a mission to have a go :whatthe:
meggie
208
392
milford haven
8y
hi,hope you are all fine,buy the tray get bill to fit it,just put a new one in mine and a toilet, see you soon.:thumb:
Ambilkate
Ambilkate
8,652
18,061
Shropshire
HYMER 654
since 2006
Well thought we would update. Our shower tray is with the doctor today as Bills attempt of plastic welding did not go the way he planned. :Sad:
Yes but no point if you don't improve the support that has caused it.
As a bodge I'd be thinking of repairing the cracks with solvent or the hot way, one or two hole saw holes, inject strong expanding foam, the bond the holes back on top of the foam.
Or maybe a layer of fibreglass cloth on top and hope it won't crack.
Both assumer you can't lift out the tray and do a prober job with fibreglass underneath.
You got it out, well you can't fail now, just make sure it's properly supported when you replace it.
Ambilkate
Ambilkate
8,652
18,061
Shropshire
HYMER 654
since 2006
Yep Bill got the shower out thanks Brian. He was not happy with the way it had been supported. :Sad: Still he can now make sure it will be fully supported. ::bigsmile:
Oct 1, 2013
7,513
19,955
Lanzarote
Nil by mouth
Lots
Get an outside shower and save £1200 :Smile:
This keeps cropping up in here. You've got wonder who designs these things.
A good layer of fibreglass CLOTH on the whole of back would be my first thought. If properly roughed up and bonded, better than new.
Ambilkate
Ambilkate
8,652
18,061
Shropshire
HYMER 654
since 2006
Well Shower tray back from doctors :Smile: Bill just got to put it back into Motorhome now. :thumb:
Ambilkate
Ambilkate
8,652
18,061
Shropshire
HYMER 654
since 2006
Thanks for this contact Stephen very pleased with the outcome 1 good as new shower tray:thumb:
regards Kate
Ambilkate
Ambilkate
8,652
18,061
Shropshire
HYMER 654
since 2006
To right Brian you have got to wonder who designs these things.
The shower tray doc plastic welded a metal mesh on the back and then recoated the tray. Sorted.:Smile:
Wildge
1,762
1,980
East Midlands
Coach built.
since 2000
regards Kate
:thumb:
Kate is he mobile or did you take the van down.?
We are at Ludlow in May and could do with a repair if he is easy to find.:cry:
thanks Jude
Ambilkate
Ambilkate
8,652
18,061
Shropshire
HYMER 654
since 2006
:thumb:
thanks Jude
We took the tray out and took it to him. He did say he usually did them in the van but we had already took it out. Easy to find no probs.
regards Kate
