Setting Freeview Arial (4 Viewers)
chrisboyo
1,317
818
Newport South Wales
Autosleepers Sussex Duo
5 + 30 years a tugger
Can anyone tell me how to set up my free view arial for the best signal
At the moment I can only get BBC channels
Chrisboyo
Chrisboyo
Copy the direction and orientation of any aerial you can see.
If you can't see any other aerials you need to find the local transmitters on line, noting direction and orientation ( H or V ).
Harder than satellite coz you could be pointing anywhere.
chrisboyo
chrisboyo
1,317
818
Newport South Wales
Hi Mixter
The tv is the one I use in my office at home, we use freesky sat on our main tv but I want this one separate from that so that I can watch my rugby/footy when SWMBO watches her stuff
I am useing a freeserve digibox but it tunes in only to BBC pogs
chrisboyo
2,347
10,197
Have you checked the Freeview coverage in your area.. ?
We are on the fringe of the signal, and despite a good arial pointing correctly had similar issue, so gave up and use Freesat
Scout
3,959
121,410
South Yorkshire
chic c line
I gave up on mine, it takes age sometimes, I belive you can get a freeview signal location finder but have no experaince of it.
Mixter
227
Keighley, West Yorkshire
Now a year - cant believe it!
I dont have a lot of faith in the freeview boxes. Id sooner have it built into the telly from the off. One less 'link' in the chain to go wrong!
ps is there such a thing as a 'freeview' aerial??
peter marshall
2,466
1,704
Cleveleys,Lancashire
Low Line
9 Years
Hi Chrisboyo
I bought a freeview / recorder from Asda, plugged in loaded up fine, BUT would not load any BBC Channels so took it back for exchange, replacement now working fine, It might be something similar. Pete :thumb::thumb:
GJH
29,450
38,827
None, now sold
2006 to 2022
Are you using a full size aerial (roof or loft mounted) or one of the small indoor table/set top box aerials?
If it is the latter then it may not be of sufficient size to pick up the lower powered transmissions. I've had that experience using a table top aerial for a TV dongle in this PC.
Satandpcguy
Jun 18, 2008
694
425
Gandia, Valencia, Spain
Don't own one yet
remember that Freeview DOES NOT cover the whole of the Uk, due tot he limitiations of the transmitters and geography of certain areas....
...hence why Freesat was developed.
go to
http://www.freeview.co.uk/
and go to the freeview availability checker (click on the option "Can I get Freeview" and input the postcode of the area you are in)
Mixter
227
Im using a bog standard roof aerial on a 2m pole, though a freeview telly. Its not failed yet - pointing in ANY direction!
Maybe ive been lucky so far? Interestingly, hooking it through the booster box inside greatly impeded performance. So now its twig straight into the telly.:Cool:
43,337
49,538
if your free view box has a reset button (may be just be a hole to insert a paperclip, somewhere on the back/front) try resetting the box to factory default then try again.
bobandjanie
8,165
15,812
Javea, Spain
Pilote V600g
Hi Chris, we have one of these:
[ame]http://www.amazon.co.uk/Philex-SLx-27867R-Digital-Strength/dp/B001GXQUNQ/ref=cm_cr_pr_pb_t[/ame]
The only place We have been with NO PICTURE :Doh: is Stratford show.:cry: But apart from that a good signal every time.:thumb: Bob.
