Seitz window blind.
Discussion in 'Motorhome Chat' started by elamessa, Aug 28, 2014.
  1. elamessa
    elamessa Funster
    May 20, 2009
    511
    480
    Haute Vienne, France
    On a recent trip one of the window blinds end piece broke and made a slight tear to the blind materiel as well so the blind will not stay down (closed). Does anyone know how to remove the whole blind from the window so that I can look at a repair it is a seitz blind with net behind and both pull down from the top.
    thanks in advance for any help.
    • Like it Like it x 1
  2. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    you need to remove the inner trim and unscrew the frame. Do make sure the window is supported outside or it may well fall out.
    • Like it Like it x 3
  3. Tootles
    Tootles Funster
    Sep 14, 2013
    9,322
    33,516
    Lancaster
    Is this any use to you???
  4. tambo
    tambo Read Only Funster
    Jun 21, 2014
    875
    637
    Dunfermline fife scotland
    It shouldn't to be honest as it will be bonded in .....i just removed and resealed all my seitz windows yesterday and had to prise them off the bodywork as theyre stuck with mastic
  5. elamessa
    elamessa Funster
    May 20, 2009
    511
    480
    Thanks for your replies.
  6. chaser
    chaser Funster
    Feb 16, 2013
    7,972
    9,034
    uttoxeter
    Don't know wether yours is the same as ours, but it has a silver flat bar at the bottom and ours ripped off all along and the blind went up and all tension gone but if you get the bar off , it only slides off then fold the blind around the thin plastic thing and slide it on again then take the the cover off the top of the blind and tension it up again with screw driver, no need to remove it.
    Probably not very clear but if you want more info just ask(y)
  7. elamessa
    elamessa Funster
    May 20, 2009
    511
    480
    Thanks for all replies.
    Seitz blind now repaired with some strong glue and scotch tape.(y)(y)
  8. Tootles
    Tootles Funster
    Sep 14, 2013
    9,322
    33,516
    Lancaster
    Sheeeeesh......All that professional knowledge at hand, for just a tenner a year!!! (y)(y););)
