Sealant Removal
Discussion in 'Tech/Mech General' started by MickyP, Oct 5, 2013.
  1. MickyP
    MickyP Funster
    May 13, 2012
    125
    47
    Alhama de Murcia, Spain
    I am about to change my roof vent for another with a fan, what is the best way to clean the (Sikaflex) type sealant which seems to get everywhere ????
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,252
    17,924
    YO11 2BD
    maybe white spirit if its still wet.
    if its dry...nothing, just trim the excess with a craft knife and leave the rest.
  3. Allanm
    Allanm Funster
    Jun 30, 2013
    3,247
    4,415
    Cotes d'armor, France
    Ive used a De.Solv-it sealant remover kit. It removes acrylic and silicon sealer and available from Amazon.
    Do as Pappajohn says and scrape off as much sealant as you can. Then apply the sealant remover, leave 20 minutes and the rest just wipes away.
    Well, thats the theory. In practice, although it works, it needs a bit more elbow grease.
    Never used it on Sikaflex but it should work.
    Allan
    • Like it Like it x 1
  4. FULL TIMER
    FULL TIMER Read Only Funster
    May 31, 2012
    796
    712
    NORWICH
    We always use a non setting bedding mastic for roof vents something like this http://www.campervan-motorhome-elec...k/p194_carafax-IDL99-non-setting-sealant.html
    depend how flat your roof is I tend to put two good thick beads around the vent flange using almost a tube per vent, when screwed dow or clamped depending on the vent fixing method plenty will squelch out around the edges, you should be able to scrape nearly all of this off using a plastic filler spreader or something similar any excess left a bit of white spirit on a clean rag or better still break cleaner. we found that the polyurethane mastics like sikaflex, tigerseal etc can eventually separate from the plastic letting water in. just noticed the link takes you to a grey coloured mastic, white is also available
  5. Traveller_HA5_3DOM
    Traveller_HA5_3DOM Read Only Funster
    Jul 13, 2012
    428
    326
    Following the Sun
    You will find that sykaflex is not normally used as an original fit because it works so well and it is very time consuming to remove.
    If you do have it fitted I use a commercial cheese wire and a couple of sort lengths of broom handle to make a hand held cutter. With this you can get all you need to remove from the van roof. Remember with sykaflex you need to leave a couple of mill thickness to obtain it's strength. If you pull it right down with the screws it does not have the same strength so make up some spacers to give you that gap and remember to put some more in those areas when you remove them.
    I generally use thinners to degrease the area before applying new stuff, it drys really quick.
  6. mentaliss
    mentaliss
    Nov 2, 2012
    657
    308
    Lancing
    bar far the best! Tec7 adhesive remover will not damage your plastic as its not chemically based, been using it for years:Cool:
