Satellite dish and tv hook up (1 Viewer)
Gaynor369
30
Bolton
Coach built
New
Satellite dish and tv hook up- thick moment
Hi, we are now getting to grips with our lovely new found weekend freedom. We have a tv in the van which is brill and built in free view and DVD etc.
Now the thick bit, where does a satellite dish feature, I have seen other vans with these on tripods and if you have one do you somehow need to subscribe somewhere.
Also a lot of pitches we stay on have tv or satellite hook up or both, whats this for and what do we need to do if anything.
May sound thick but I guess you never know unless you ask!
Geoffers
506
215
Groby Leicester
When using satellite dish 3 options.
Freesat & Free to air boxes,no subscription.
Sky , subscription but if you subscribe at home you can use the same card.
On site freeview ,cable straight into TV
Satellite on site not to sure but I assume you still need a box:Smile:
17,637
43,382
As mentioned tv point on site is just an aerial like on your roof at home, just plug into freeview box or tv if built in freeview
satellite point is just to the dish, so you still need a sat box, either sky or free to air type to decode for the tv
sat dishes either on van or tripod supply the sat decoder as mentioned before and gives a good picture and uk tv as far south as spain
G
Gaynor369
30
Bolton
Coach built
New
Still don't get it, so we have free view in our tv, why would we need on site tv hook up, is that for a better signal and if so what is needed to hook up and does the sat dish just give free view channels
G
Gaynor369
30
Bolton
Coach built
New
Ahh so we need a Long coax thing to plug in and that makes for a better signals rather than relying on our aerial or do the site provide their own free view when you plug in
Sat dish, I would need to buy a dish and box and subscribe? Without this the free view is no good out of country?
17,637
43,382
site tv hookup gives a far better aerial reception...you just run a coax wire from post to your tv aerial point
satellite can give either just freeview channels or if you take a skybox and card from home will give you everything you can watch at home
17,637
43,382
no the sites dont have a freeview box built in, just an aerial
freeview tv through an aerial, you need to be within broadcast range, so no good out of uk. Satellite will pick up way down south, but you need to buy either a sat freeview box or a sky box, with or without subscription. without a subscription on sky you can get a freesat card giving basic channels for about ÂŁ10
Geoffers
506
215
Groby Leicester
Many sites are in poor reception areas in which case you can purchase a long coax lead and plug into the sites boosted supply.
Sat boxes, freesat is for use in the uk only and give more or less freeview channels (but not all) uses sat Astra 2B
Free to air uses any sat anywhere . so vast array of channels English & foreign.
Channels on free to air are generally free sat but spread about:Smile:
madbluemad
Banned
Jan 26, 2008
3,327
239
spain
just looking
since 1980
To use you telly with a satellite you need, a decoder which connects to your tv. There are lots of different types of decoder.
You can use a sky box if you have one or buy a decoder from Maplins or Road Pro.
You will then need a satellite dish. There are lots of satellite dishes. You could use a sky dish and attach it too a pole or tripod which you would position outside of your mh somwhere.
The satellite dish is then attached to your decoder via a length of co axial cable.
You can buy a dish from Maplins or Road Pro.
You can buy a dish that sits on the top of your mh or on the ground. Whatever suits you.
You dont have to use Maplin or Road Pro, they are examples. Road Pro has a very good web site which will explain telly's in mh's for you.
Dave Newell who is a site member and sponsor will give you all of the advice you need for setting up ypur telly.
Jim
:Smile:
aba
2,775
1,112
yorkshire
dec 2009
after all that said you may need some way of getting said cable to the inside of your motorhome for which there are a couple of ways.
1st you can buy a flat cable that you just put through the bottom of a window or locker door.
such as this one.
[ame]http://www.amazon.co.uk/Satellite-flat-window-cable-connectors/dp/B003JI3RLY[/ame]
or you could get an outside connector like this one.
and either fit it yourself or if you don't fancy drilling holes in your motorhome get someone such as Dave Newell to supply and fit it for you.
