sat nav
Discussion in 'Tech/Mech General' started by Hayleylulu, Aug 1, 2010.
  1. Hayleylulu
    Hayleylulu
    Feb 17, 2008
    5,391
    3,880
    Full timing in the van
    plugged sat nav in Sig lighter and all smoke came out and it was hot so plugged my phone in and know problems any one no why or can help :Blush:
  2. BobProperty
    BobProperty Read Only Funster
    May 20, 2010
    272
    32
    Stockport
    If I've got this right, it sounds like the plug on the satnav charger is the cause of the trouble. Do you mean that the phone charger works OK?
  3. Hayleylulu
    Hayleylulu
    Feb 17, 2008
    5,391
    3,880
    yes the phone charger works ok
  4. BobProperty
    May 20, 2010
    272
    32
    Stockport
    So you have to assume the socket is OK and therefore the problem lies with the plug part of the charger for the satnav. Does it have a fuse in it, do you know? Has it melted at all? Have you got a spare one or can you borrow one to test out that it is that lead that is causing the problem?
  5. smudger
    smudger Funster
    Feb 3, 2008
    497
    703
    ireland
    hi martin...first thing to doo, is chuck sat nav as far away from you as you can...then plug back in phone charger and wait a bit longer..as it could be better quality wiring,so will take a bit longer to go on fire.:BigGrin:..failing that,,me and jj know a certified electwonics engineer...he will be at shepton,so we can point you in his direction if you want,,,best of luck....smudger...:BigGrin::BigGrin::BigGrin:........ps give us a ring wen you get back...
