Sail and Trail, Newark. My Experience. (6 Viewers)
jb0371old
465
408
Autotrail
1 year
Disclaimer (for the lefties on the forum): In no way does this post have anything bad to say about GAS IT refillable bottles or the company (they where very helpful as normal), also this is a true account, so no posts about libel or slander or any of that malarky.
Background on myself, before the doomsayers reckon I shouldnt be fitting my own gas system - Worked in engineering since I was 16 in the automotive and water meter industries, worked offshore as a service technician on lifeboats and winches and now back in the pharmacutical industry, I have also renovated my own house redoing the electrics and fitting oil central heating.
So now for the story, grab a beer and prepare to be entertained with laughter and Oh my God moments.
Whilst at the Newark sjow the other week we finally bit the bullet and brought a 2nd bottle for our GAS IT system. So I asked about putting in a changeover valve as well, I mentioned that I had a 37mbar regulator, so would that work, the first guy to be fair didnt know, so he called his mate over who said it would be fine (I did explain the 37mbar regulator to him as well). As they didnt have enough pig tails they gave me the one of off the display.
So a couple of weeks ago I finally got around to fitting it, as those of you that may have done this job, you do need to prepare yourself, as space is tight and you need to plan which union to tighten up first as if you do the wrong one first you will have to undo some to redo the right one. Being a typical bloke your now expecting me to not read the changeover valve literature, well I did as it is a gas system and I aint that stupid. Remember the bit about 37mbar system, well the opening line in the literature, was this valve works between 30 mbar and 35 mbar.
So I thought it best to contact Sail and Trail, I rang them over 2 weeks, and left at least 2 voicemails and 1 email, know you would have thought they would get back to me as it is quite a serious cock up, I rang GAS IT and got through straight away, and they said catagoricly that the changeover valve would not work on my system and they shouldnt have told me it would, as at best my appliances wouldnt work and at worst it could a flame thrower as soon as we turn the oven on. I brought from GAS IT a brass manifold that would do the job and it would be a manual changeover system now (so be it, no great dramas, plus ÂŁ20 cheaper).
As luck would have it I finally got through to Sail and Trail the next day and finallyt got to spoke tone of the brother who own it called Luke. I never swore or called into question his parentage, but did express my outrage that his staff had given me wrong advice that could have had potentially lethal results, he didnt really seem to be that bothered about it (my own personal thought). And if I returned the valve he would give me a refund.
As the brass fitting came I then installed the 2nd bottle finally got to attaching the pig tails only to find the tail that had been the display one had no O rings on it.
So back on the phone to my mate Luke, who did apologise and after discussing which hose it was he was just going to send me out a new pig tail. Fair enough.
Well it came to today, so I opened it up only to find he has sent me a POL assembly hose. Back on the phone, and even though I was angry I never raised my voice but just called him incompetent and that I had lost all confidence in him, he just put the phone down on me.
So at the Theford bash I will be donating the hose to the charity raffle. And I will be going down the plumbers merchant for a couple of o rings.
I am fairly sure that they couldnt get themselves laid in a brothel.
jonandshell
5,476
8,299
Not got one!
I'll see if there is any of my mad uncle Matt's valium left Jeff!:)
May 29, 2013
2,603
19,281
Tyneside
Chausson best of Flash 10
Several years now
A frustrating episode for you, but looking on the positive side at least Snail and Trail didn't try and feed you any Bullsh*t, ie giving a crazy reason as to why they sold you the wrong part, such as "are you using it in France, then you'll need a 37mB connector" or the like.
I can forgive mistakes, it's when Companies try and Bullsh*t you when they are clearly in the wrong that makes me mad !!!
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
I'm a bit baffled by the "37mbar" setup you have. Normally 37 mbar regulators are bottle mounted so would have no pigtails. The auto changeover system takes full bottle pressure (6 Bar approx) via the aforementioned pigtails and would usually be connected to the input of a bulkhead mounted regulator which drops the pressure to 30 mbar, the output pressure of the regulator has no bearing on the changeover unit as that works on full bottle pressure. The only alternative I know of is a combined auto changeover and regulator but that simply does away with the joint between the two items. Can you identify the parts you were originally sold on the Gasit website for clarity please.
D.
J
jb0371old
465
408
Autotrail
1 year
My motorhome is an 03 autotrail, that came with just a normal propane red regulator, so I originally just bought a 1 bottle gas it system with a pol adaptor that the reg screwed into that in turn screwed into the gas it bottle, so with the new bottle I removed the pol adaptor and just fitted the normal pig tails, that now screw into a brass manifold that the reg also fits into.
http://www.gasit.co.uk/pol-bulk-head-manifold-for-2-bottles.html
DuxDeluxe
14,659
72,818
Planet Zog
A woosh bang van
Well, I gave it a "like" for the way the story was told, not the story itself. There are some people around, and they breed......
Also gave a "like" for the flat coated retrievers......
Steve and Denise
5,296
14,097
Spalding LINCS
A Class Carthago
Since 2008
I had some dealings with Sail & Trail bought a genny from them proper nightmare. They should stick to selling toilet rolls they are experts on that subject.
DuxDeluxe
14,659
72,818
Planet Zog
A woosh bang van
Yeh quite "smelly" that LPG "odour"?:whistle::whistle::D:D
Try replenishing the stenching agent used in an LNG tanker..... Waterproof disposal overalls, plastic gloves, breathing masks everything. Throw all away afterwards and after half a dozen showers you still stink. Odour threshold of the methyl mercaptan is about 2 parts per Billion!!
DuxDeluxe
14,659
72,818
Planet Zog
A woosh bang van
I buy my stuff direct from Gasit. Those guys know their stuff, very helpful and at prices you can't sniff at.
That is where I got my stuff from. Good service
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
So what was the original changeover unit that Sail and Trail sold you? So far my take is that you didn't explain clearly enough what you had and how you wanted to set it all up, I only say this because you haven't explained it clearly here either.
D.
PeteH
6,853
9,032
East Riding of Yorkshire
Rapido, 999M.
18+yrs plus 25+Towing
Tell me about it!. I used to do Statuary internal examination of Calor`s Road Fleet and Static 10 year inspections!. This was AFTER they had been "gas freed", ventilated and cleaned!.
My wife would not allow me in the house until I stripped and put my gear in the washing machine, and THEN I had to take one or two showers before the stench faded enough to be allowed in the lounge!!!.
Pete
2,350
10,215
sorry to say this.. don't mean to sound harsh.. (and I'm not a doomsayer) but I've come to that conclusion..
if you don't understand how a gas changeover valve works nor what is required to install it with twin bottles, I suggest you ask a qualified LPG gas fitter or have them do it.
this is how it is connected.. Gaslow or Gasit .. makes no odds .. same
as you can see .. as Dave explained, the changeover valve has full bottle pressure
J
jb0371old
465
408
Autotrail
1 year
Ok, I fully understand how a gas change over works, and from the excellent picture below the big black box states EXISTING 30MBAR REGULATOR. As stated in my post I have a 37MBAR REGULATOR, they are not interchangeable, I spoke at lenght to the sales men asking will the changeover valve he was selling me, work with a normal propane regulator remembering that it is 37mbar, which he said yes. What he should have told me was no it will not work as the pressures in motorhome changed around 2005 ish from 37mbar (red regulator) to 30mbar (something like in the picture below) but you can get a brass manifold that will work manually. See the link
Does that it make it any clearer?
So this is my system (minus the 2nd pig tail as the o rings where missing) just waiting a delivery from gas it. i have put all the pipes in a protective shroud to protect against rubbing and road dirt (esp the main filling hose). As you can see int he background the red 37mbar regulator screws into the brass manifold.
11,956
16,571
I think you might have asked the wrong question. The changeover valve (whatever you stick on the end of it) is at the current tank / bottle pressure. It does not care what device it feeds. It's the equipment in the van that is affected by regulator pressure so the question should probably be 'will a 37mb regulator connect directly to the changeover unit'. Incidentally the van would be fine with the new-style regulator as it's already designed to cope with the lower pressure of butane regulators.
Huwmari
253
183
Benimar Mileo 201
since Apr 2013
So do we - this is the second van in which we have had a GASIT system and their staff have been fantastically helpful.
Badknee
7,408
413,084
notloB
Vantage Neo
Living the dream.
We had a look at the GasIt system at Peterborough last year but decided not to buy it from a dealer and get it straight from GasIt, I'm glad we did.
J
jb0371old
465
408
Autotrail
1 year
I brought the first bottle from gas it, who cant be more helpful or do enough, stupidly we just brought it from the show as we keep on talking about it but never got around to it. So we bit the bullet, quite literally.
All well that ends well, should get o rings from gas it tomorrow, then fit, fill and check unions, then forget.
mick noe
Apr 14, 2009
638
539
near Boston Lincolnshire
low line
no still cant even see the problem,if appliances work/are designed to work on 37mb what will have changed ?why the flame thrower mention ........sorry to be so thick! I fitted my own system from gasit very happy and no problems.
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
For information only, 37 mbar is interchangeable with 30mbar, the difference in pressure is so minute that the appliances will not notice. The purpose of the change to 30 mbar universal reg is to simplify switching between propane and butane (traditionally propane would be run at 37 mbar and butane at 28 mbar, 30 mbar is a compromise pressure at which either gas can be used without major issues arising.
You still have not identified the original changeover device sold to you by Sail and Trail in error. The manifold you now have is not an auto changeover unit by the way.
D.
J
jb0371old
465
408
Autotrail
1 year
To be honest if your not going to read my post properly then dont bother replying, the auto changeover was just one from the gas it shop, and I did mention that I would have to manually change it as the brass manifold is just that a manifold. You give me grief for potentially not asking the right questions and when I get an answer from gas it themselves that the 30mbar valve would not either fuel the appliances properly or cause a flame thrower then you give me grief about that as well, so do I listen to gas it for part of it or not ask advice from people? I can do the monkey work, I just asked the salesmen advice and he advised me wrongly as told to me by gas it.
http://www.gasit.co.uk/leisure-gas-...ge-over-valves/automatic-changeover-unit.html
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
Get over yourself mate, I asked a few questions as I didn't understand what you had been sold. My point being that you haven't made it clear on here as to what you had/wanted so perhaps you weren't clear to the Sail and Trail salesman. The flamethrower situation is an odd one and I am trying to understand how the kit you were originally sold would cause it. All I am asking is that you clarify exactly what you were originally sold and why it was not suitable, is that too difficult? I apologise if my style is a bit too blunt for you but that's just me, like Popeye the sailor, I is what I is!
D.
J
jb0371old
465
408
Autotrail
1 year
Not clear. I saw a salesman and told him what I had (lpg system) on my van and that I wanted an auto changeover valve etc with 2nd gas it bottle, what wasnt clear? He advised me wrongly and the gas it guys said it could be potentially dangerous. I asked the saleman to advise me as a proffessional of lpg systems, so he could supply me with the correct parts, I am more than capable of installing, I didnt just buy something then install it and then blow myself up. There are plenty of posts on here and other forums I am on with people just buying things installing them and then wondering why they dont work or get hurt. Any further clarification needed?
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
Yes lots. You still haven't answered the question of what exactly they sold you in the first place. Calm down, read my posts again and then answer my questions succinctly and we may get somewhere.
D.
J
jb0371old
465
408
Autotrail
1 year
1 x gas it bottle. 2nd bottle variant
2 x pig tails - 1 with missing o rings
1 x filling pipe
1 x changeover valve
T piece union - to fill both bottles
Plus a plastic bag that it all came in, that I didnt open till I came to fit. Fairly sure I got the bag for free:D
Told I had everything I needed for my system.
Jul 29, 2007
6,551
39,705
Ipswich
RV and PVC
30 years
An auto change over valve is simply that, it does not alter the pressure, if your 37mb reg worked before, why wouldn't it work on the change over valve? I think this is the question people can't understand.
Ian
jumar
3,780
11,628
Spain
Hymer Tramp
Since 1994
Interesting stuff. Great reading, loved it.
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
Right, thanks for that. Either you or they or both of you were confused about what you already had and what you wanted to achieve. As explained earlier the auto changeover works at full cylinder pressure and its output is full cylinder pressure which would normally be connected to a bulkhead mounted 30 mbar regulator. As you have a 37 mbar cylinder mounted regulator this is of no use but it would not cause the flame thrower effect unless you were to install it with no regulator at all and I will assume you are not that daft. The new manifold you have is a neat solution, an alternative setup for you would be to have a cylinder mount reg on each bottle and connect their low pressure outputs with a tee piece.
D.
