rooflight seal leaking..
Discussion in 'Motorhome Chat' started by Stephen & Jeannie, May 16, 2009.
  1. Stephen & Jeannie
    Stephen & Jeannie Read Only Funster
    Aug 27, 2008
    4,198
    3,262
    Gobowen near Oswestry !!
    There was post not so long ago about seals around heki rooflights leaking..I can't find it..:Angry:.....My heki has started to leak again despite the wonderful Brownhills 3rd attempt to remedy it (is the Brownhills snitch on line ? if so take note !!!) So , what is the best substance to paint over it that creeps in and around and never dries???...:helpsos::thanks2::thumb:
  2. weymard
    weymard Read Only Funster
    Jan 25, 2009
    250
    CHERBOURG NORMANDY
    My opinion : remove the Heiki roof, clean it and the MH roof with acetone, use Sikaflex 291 to past it ! Be very generous with sikaflex. Tighten the screw to the max. Smooth the joint which overflows outside with a wet finger .:thumb:
  3. Stephen & Jeannie
    Aug 27, 2008
    4,198
    3,262
    BUMP !!!!!:Eeek: and bump again :Eeek:
  4. Brambles
    Brambles Read Only Funster
    Sep 9, 2007
    49
    Tayside
    Hi,
    While since I have posted on the fun forums.
    ... check it is not any fixing screws in the roof light itself that are leaking and not necessarily frame sealing to roof.. May need new washers under them or just tightened up.
    Jon.
  5. scotjimland
    Jul 25, 2007
    29,048
    25,741
    Suffolk
  6. 45eEver
    45eEver Read Only Funster
    Apr 15, 2009
    267
    If you reseal or paint some gloop on, I suggest you use masking tape to do a neater job.
