Roof mounted air con. (6 Viewers)
MJG1959
136
124
Cleveland UK
If buying a new van what does having one fit do to your damp ingress gurantee?
Or if there is space would it be better to go for one in the bed locker?
old-mo
Extra Special
16,343
93,692
Weymouth. Dorset...
Nearly aint got one.
Caravan & motorhome 45 + yrs
Better off buying a couple of fan`s... (y)
Noisy things, cannot sleep with them on, and have to be on a desent EHU to use them...
Make a neat job and put a fan assisited sky light in and you can have my virtually unused one.. :wink:
MikeD
3,936
3,697
London
IH PVC
We have a roof mounted air con unit and as old mo says its a noisy thing.
Bit like leaving the hoover running in the corner of the bedroom.
MJG1959
MJG1959
136
124
Cleveland UK
Cheers all. I've DMOR and got the answer I needed to my original post.
Thanks.
buckby
213
147
nottinghamshire
We use our roof mount for the de humidifier and we use it in the mornings before we get out of bed for heating the compressors on them are a bit noisy probably the newer ones are quiter
Forestboy
5,023
8,338
Forest of Dean
A Class Hymer B694 tag
Thanks.
No we had one in a locker in a previous van it was noisy and the van vibrated all the time it was running. If you really need one roof mounted is best. (y)
MJG1959
MJG1959
136
124
Cleveland UK
Cheers but I was meaning I had found the answer to my question in the first post I made ie the water ingress guarantee not how noisy the varios types are. On that point I have had a look at a couple of you tube videos too and although the roof mounted ones do make a noise I think I could live with it. I would have to hear one first hand though before making a decision.
Forestboy
5,023
8,338
Forest of Dean
Our current van has a roof mounted never leaked or let water in and its over 12 years old.
We occasionally use it down in the Mediterranean if its exceptionally hot. It is noisy but not enough to keep us awake if on low setting and now where near as noisy or vibey as the locker one.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
I would just love it to be hot enough to complain about it :LOL:
I even took the "Fantastic Fan" off as it blocked out too much light, much prefer to see the sky day or night.
MJG1959
MJG1959
136
124
Cleveland UK
Cheers.
rolandrat
436
258
Lancashire
Hi Top
I had my roof aircon removed, it wasn't needed and also added extra weight. A 400 x 400 sky light was put in its place and increased the light. We have travelled in very hot weather and found air-con unnecessary, in fact a good table fan was adequate.
rikfos
315
199
hereford
I have one fan clipped on the locker and that is on 24 hours a day and a floor standing one that keeps the van reasonably cool all day when we are in Greece and the temps are in the high 30's
MikeD
3,936
3,697
London
IH PVC
We have a Dometic Freshlight and it does let water in when we park the van on our drive. It's on a front downward angle. Strange thing regarding noise when running is that it's really quiet outside. Your neighbour would never complain but in doors it sounds like you left the hoover running in the corner.
I would also say if you are thinking of buying one - Don't. They apparently do not have enough evaporation units (to allow for the window) and don't really cool the air that well. We have had Dometic out to ours and the engineer says it's as good as it gets.
Nov 6, 2011
438
656
Worthing
Knaus Sky Ti
2001 to date
We have roof mounted air-con. Noisy and never used it, even in hot weather. Total bloody waste at the expense of natural light. If van is level and we get a big down poor it lets water in. If we do not up-grade this year, its coming out!!
Keith :cool:
Techno
Jul 28, 2010
15,475
20,756
May 2010
BTW HAE wondered WTF DMOR is? :LOL:
How about sharing your findings?
MJG1959
MJG1959
136
124
Cleveland UK
Well it's vauge to be honest. But using the wording in Elddis' which refers to the warranty being void if any structural alterations are carried out it to me implies that fitting a roof mounted air con would provide the ability to wriggle out of a claim.
Of course the other thing I discovered when I DMOR was that sometimes they are swapped for a std. 400 x 400 skylight which it could be argued does not constitute a structural alteration. Cutting a new hole however possibly could be.
I think to get a definitive answer would require something in writing from a dealer or manufacturer.
Techno
Jul 28, 2010
15,475
20,756
May 2010
Yes all aircons generally replace a factory fitted heki or the like.
If you put yourself in the converters shoes I think it would be quite usual to negate warranty on a heki being removed that was sealed by them unless the aircon is fitted by themselves. I would expect that leakage after fitting by anyone else would be entirely the responsibility of the supplier/fitter unless approved by the converter.
EDIT
Of course there is also a cable entry through the roof for the power supply to consider just like for any other roof mount accessory, satellite, solar, aerial, etc
DanielFord
3,020
3,086
We have a roof top air con, and this post comes up lots, so tomorrow when I visit the van, I am going to run the unit in fan, heat and cool modes and I will video it, with some baseline noise, so that everyone can judge the actual noise that this things make.
BTW for reference, I agree, in cooling mode it would be impossible to sleep, partially from the noise, and partially due to the neighbours you have woken up wanting to kill you!! :D
MJG1959
MJG1959
136
124
Cleveland UK
That would be appreciated actually so thanks. Please confirm your make model and year of manufacture when you do.
Thanks again.
Judge Mental
Sep 2, 2009
6,650
5,883
Sarth London
Possl 636 FR panel van
1994 and beyond...
Or trying to sleep on a jet flight! take the advice, save money and payload and use a couple of fans....You soon get acclimatised anyway. Plus it normally cools down at night unless a heatwave. even fans need turning off at night as it normally gets too cool
MikeD
3,936
3,697
London
IH PVC
I agree with above I would not buy another air con unit. In three years I suspect it works out around £100 per night so far. :(:rolleyes:
Judge Mental
Sep 2, 2009
6,650
5,883
Sarth London
1994 and beyond...
thats what I always thought and what we do..But was in a Carthago n Italy a few weeks a go and there was very quiet and van lovely and cool. never got the name of it:(
we had a Waeco roof unit on our 2007 Euramobil..vowed never to bother again..now not sure and as we always go away July/August might order on new van..
has anyone got a recommendation please and an idea as to weight would be helpful.. as I think they have improved?
Eddie
18,038
48,155
DMOR stand for "Distinguished Member of the Regiment" according to Google. Did the OP ask Old Mo? Or at a guess is it Did MOre Research?
Techno
Jul 28, 2010
15,475
20,756
May 2010
Done my own research
Enword
1,900
7,999
Devon
Coach Built
Race van conversion for years
We use ours a lot at race meetings nice to put on cool leathers when its hot especially when you sat on the exhaust in the bike!!, It is a bit noisy but can sleep with it on low fan setting, but usually put it on for a couple of hours before we go back in the van so that its cool to go to bed, not had a leak yet fingers crossed(y)
