Roof Marker lights (1 Viewer)
cazzarazza14
56
49
Stafford
Autotrail Apache 700SE
March 2015
Hi all
Does anyone know where the fuse is located that run the front roof marker lights I have checked the lights there doesn't seem to be any power getting to the units it seems strange as they both stopped working at the same time that's why I'm thinking fuse blown
I have checked the
engine fuse box
Fuse box by drivers door
And the fuses on the Sargent fuse board
I'm now lost can anyone HELP!!!!!
Sep 11, 2014
1,013
3,483
West Sussex
We also noticed recently that our front and side marker lights weren't working while on the move, it turns out that you need the 12v power supply turned on for them to work.
Well, this worked for us (Swift Sundance), could it be the same issue??
Bluestar
279
164
Brighton
Class
10 years.. On and Off
As they are marker lights I would thought they would be taken from a feed off of the side light circuit, Corrosion?
cazzarazza14
cazzarazza14
56
49
Stafford
March 2015
:oops2:I had vehicle running every light works except two front markers on roof baffled
One of ours stopped working, there was 12V there but the ground, taken from the metal skin had gone. I had to run a wire from skin to chassis to get it going.
andy63
4,672
15,018
south shields
since 1990
I doubt this will help , but was looking to see if it was possible to google a fuse location , which as has been said thought would be on side light circuit.. the wiring diad seems to show one the front marker lights been fed from different supplies, one from a rear light connector which doesn't seem right..
says its from an autotrail apache handbook page 61 which im assuming is van you have .
best of luck..
ta andy
jonandshell
5,476
8,299
Not got one!
The lights won't be supplied by the Sargent unit.
They will be connected to the sidelight circuit somewhere, probably very badly because motorhome manufacturers are useless.
A corroded terminal will be most likely.
cazzarazza14
cazzarazza14
56
49
Stafford
March 2015
image.jpg image.jpg image.jpg image.jpg I finally figured it out there was a hidden fuse box under the floor right behind the drivers seat and passenger seat it is called an em50 fuse board and the things it runs is shown on the attached pics thanks all for the advise and anyone with an autotrail please use or keep this advise pics attached
Abacist
3,798
11,185
Devon
N & B Arto 88F Tag
since 2013
That's the box that connects the cab electrics to the electicss loom in the habitation area although as can be seen from above the electrics are obviously not exclusively habitation electrics.
cazzarazza14
cazzarazza14
56
49
Stafford
March 2015
There are four fuse sections
Em50 in pictures
Sargent unit
Fuses in engine compartment
Fuses by drivers seat
Took me a week to find 1 little fuse
Bluestar
279
164
Brighton
Class
Oct 14, 2007
4,009
6,282
Rochester
Auto-Trail Mohawk
16 fun filled years
On my 2007 Fiat based Besseccar the marker lights were not fused, when a bulb went I replaced it with new but one side of the van's side/marker lights rear and front didn't work, I spent ages trying to fine the fuse to no avail so I did a bit of research with Mr Goole and apparently because the loading is low the onboard computer handles the side/marker lights via the canbus system, if it has a problem it just shuts that circuit off. The advice was that the computer needed resetting by disconnecting the vehicle battery for 20 mins which I did then reconnected and every thing was ok.
