Roof Marker lights
Discussion in 'Fiat' started by cazzarazza14, Sep 13, 2015.
  1. cazzarazza14
    cazzarazza14 Funster
    Apr 21, 2015
    56
    45
    Stafford
    Hi all
    Does anyone know where the fuse is located that run the front roof marker lights I have checked the lights there doesn't seem to be any power getting to the units it seems strange as they both stopped working at the same time that's why I'm thinking fuse blown
    I have checked the
    engine fuse box
    Fuse box by drivers door
    And the fuses on the Sargent fuse board
    I'm now lost can anyone HELP!!!!!
  2. reckless
    reckless Funster
    Sep 11, 2014
    448
    600
    Sussex
    We also noticed recently that our front and side marker lights weren't working while on the move, it turns out that you need the 12v power supply turned on for them to work.
    Well, this worked for us (Swift Sundance), could it be the same issue??
  3. Bluestar
    Bluestar
    Nov 3, 2014
    280
    168
    Brighton
    As they are marker lights I would thought they would be taken from a feed off of the side light circuit, Corrosion?
  4. cazzarazza14
    Apr 21, 2015
    56
    45
    Stafford
    :oops2:I had vehicle running every light works except two front markers on roof baffled
  5. hilldweller
    Dec 5, 2008
    27,551
    26,644
    Macclesfield
    One of ours stopped working, there was 12V there but the ground, taken from the metal skin had gone. I had to run a wire from skin to chassis to get it going.
  6. cazzarazza14
    Apr 21, 2015
    56
    45
    Stafford
    Thanks for all advise :thanks3:
  7. andy63
    andy63 Funster
    Jan 19, 2014
    2,228
    8,542
    south shields
    I doubt this will help , but was looking to see if it was possible to google a fuse location , which as has been said thought would be on side light circuit.. the wiring diad seems to show one the front marker lights been fed from different supplies, one from a rear light connector which doesn't seem right..
    says its from an autotrail apache handbook page 61 which im assuming is van you have .
    best of luck..
    ta andy
  8. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,285
    7,985
    West Norfolk
    The lights won't be supplied by the Sargent unit.
    They will be connected to the sidelight circuit somewhere, probably very badly because motorhome manufacturers are useless.
    A corroded terminal will be most likely.
  9. cazzarazza14
    Apr 21, 2015
    56
    45
    Stafford
    Cheers funsters great info andy thanks
  10. cazzarazza14
    Apr 21, 2015
    56
    45
    Stafford
    image.jpg image.jpg image.jpg image.jpg I finally figured it out there was a hidden fuse box under the floor right behind the drivers seat and passenger seat it is called an em50 fuse board and the things it runs is shown on the attached pics thanks all for the advise and anyone with an autotrail please use or keep this advise pics attached
    • Like it Like it x 2
  11. Abacist
    Abacist Funster
    Oct 15, 2013
    1,305
    1,558
    Devon
    That's the box that connects the cab electrics to the electicss loom in the habitation area although as can be seen from above the electrics are obviously not exclusively habitation electrics.
  12. cazzarazza14
    Apr 21, 2015
    56
    45
    Stafford
    There are four fuse sections
    Em50 in pictures
    Sargent unit
    Fuses in engine compartment
    Fuses by drivers seat
    Took me a week to find 1 little fuse
  13. Bluestar
    Bluestar
    Nov 3, 2014
    280
    168
    Brighton
    Glad your sorted, shared information is King :)
    • Like it Like it x 1
  14. Diabalo
    Diabalo Funster
    Oct 14, 2007
    2,001
    395
    Rochester
    On my 2007 Fiat based Besseccar the marker lights were not fused, when a bulb went I replaced it with new but one side of the van's side/marker lights rear and front didn't work, I spent ages trying to fine the fuse to no avail so I did a bit of research with Mr Goole and apparently because the loading is low the onboard computer handles the side/marker lights via the canbus system, if it has a problem it just shuts that circuit off. The advice was that the computer needed resetting by disconnecting the vehicle battery for 20 mins which I did then reconnected and every thing was ok.
Similar Threads
  1. Tighchris
    12
    566
