roof leak cured , how to get rid of staining ? (1 Viewer)
glyndwr
43
23
Abergavenny
coach
since 1984 Chausson atm
Had a leak around a roof rail joint on my Compass m/h looks like its cured with sv sealnt but can't shift the staining caused internally , tried 1001 carpet cleaner , stainoff and most others I have seen for sale but no result so far .
Jun 30, 2010
7,924
27,229
Cornwall
1992 VW Auto sleeper Mono
Since 2005 this time
Don't know if this will work or not, but hey ho, tis worth a try (say a square centimetre maybe)
I had a Mould stain on my awning canvas, I got some "Starbiight RV Awning cleaner" recommended by someone on here (can't remember who tho) followed the instructions and it worked.
As I've said ! don't know if it will work.
Is the stain Brown?
Perhaps trial and error! Starbright and bleach? Gently does it tho!
Weak weak mixture at first?
Sorry I can't help otherwise!
Jun 30, 2010
7,924
27,229
Cornwall
Just had a quick squizz at a Victorian thingee and it recommends Lemon juice!
Trial and error? tiny square for a tester?
Kool Kroozer
1,361
2,228
Cannock Staffordshire
Low Profile Hobby Premium
Always learning
WD40 and cream cleaner are 2 most popular items i use for removing stains, don't think i have come across anything yet i haven't been able to remove with either (y)
sedge
Jul 7, 2009
5,504
13,116
Nr Jct 3 M6
C class
Aug 09 to date 9,000 miles!
Carpet stains? Have you tried Vanish carpet cleaner - the spot removal one in the spray can in this case, methinks.
If not carpet, where else?
TheBig1
17,630
43,279
if its on vinyl coated wall/ceiling board, it needs either replacing or painting usually
Jan 8, 2014
1,038
2,519
Emsworth
Bailey 740
All waterstaining on vinyl or matt substances will require a stain block. We are forever covering water stains in the building trade. You have several choices polycell do a stain block spray in a aerosol, we usually just use a oil based paint then once dry go over with emulsion.
In a motorhome this ain't going to look pleasant. magnum motorhomes sell wall/ceiling boards you could cut the section out and replace using a reciprocating saw.
Terry
11,932
9,085
Lincolnshire
Can't remember ;)
I got some roof staining after trying to wash/clean it.After cleaning it ,it was a bigger mess than before I started :(I was going to simply overboard it but decided to paint it -A full 24 hrs later and 4 coats of paint all was as new (y)If I would have over-boarded it the job would have been done in a couple of hours and no waiting for anything to dry -Still very happy with result and I also painted the Heiki blind to the same shade of off white / cream (not the frame just the roller blind bit)-I found = parts of white and Magnolia to be a perfect match (y):)
terry
GWAYGWAY
4,213
3,306
Dover
Hymer ML I 580
4 years
I have the same problem with my Chausson, It has a fabric roof lining and it is that which has a slight brownish stain where water got in some time ago, it is OK now but the stain always looks like it is still leaking. WD40 is an oil and would stain it more but a different colour . I might try spot cleaner though on a tiny bit out of sight.
Gorse Hill
2,364
1,944
Stretford
Burnster Ixeo IT 734
Fair point, sounds about right, I thought it is a fish oil but wasn't aware it would stain further
Hope he hasn't tryed it, just shows always learning
G
glyndwr
43
23
Abergavenny
coach
Yes first thing I tried , thought it had worked but when dry was still same .
G
glyndwr
43
23
Abergavenny
coach
The interior of the roof on mine is covered in a Hessian type of material .
Terry
11,932
9,085
Lincolnshire
Can't remember ;)
It's a very easy job to cover the Hessian with Veltrim -You can buy a 10 mtr roll (2 mtrs wide) = 20sq mtrs and 10 cans of spray adhesive for £105 -not saying you will need that much but it gives a idea how cheap it is on price -simply spray roof then veltrim ,stick it up and cut around cupboards -wipe off excess/overspray glue (y)Sharpe Stanley type blades needed and don't be afraid to change the blades
terry
Styx
570
2,086
Buckinghamshire
Van Conversion
since 2007
Perhaps ask at your dry cleaners if they have anything that might help...?
:smiley:
Apr 28, 2013
3,682
80,879
Alentejo,Portugal
Hymer A Class
Since the '80,s
Well haven't replied cos I got caught using her toothbrush and am only just out of hospital and had to buy her an expensive electric one as compensation!!
Seriously the WD 40 lightened it but did leave a lighter stain after drying.Think lemon juice gonna be my next test,before I put it in her G&T.
Baggers53
187
221
Stafford
I am a car body and interior repairer...this sounds very similar to a cars roof lining..
and unless you know what you are doing you do not touch these....normally replace the
lot...or treat the stained area and then recolour the lot and this is not as easy as it reads.
If you want to pursue this latter suggestion get in touch and I will advise as best I can!!!
Abacist
3,734
10,702
Devon
N & B Arto 88F Tag
since 2013
You should be able to buy a roll of roof lining paper from your motorhome manufacturer which will match your existing roof boards if you give them your serial number and manufacturing date etc. The only decision is then how much to do and to find logical places to end your replacement lining paper. You are unlikely to be able to remove water stain marks!
G
glyndwr
43
23
Abergavenny
coach
Joncris I ordered that one you recommended .
