Replacing Leisure Battery (1 Viewer)
Gollom
206
122
Preston, Lancs
Hymer B534 (1994) - Hetty
Since 2014
Going to replace this tomorrow. If I switch off the charger via the main control panel, can I simply remove/reconnect the battery? Do I need to take off/put back the cables in a particular order? (Terry told me that the battery also charges from the engine when it's running)
TIA
Nov 4, 2011
5,952
39,294
Uk
It should have a fuse near the battery on the positive wire and you should remove this before starting to remove wires.
17,641
43,445
black negative wire off first every time and last to put back on. then there is less risk of shorting. switch off charger a couple of hours before disconnecting ideally
11,957
16,573
............. and if you have any solar panels disconnect them from their controller before doing anything.
