Replacing Leisure Battery
Discussion in 'Tech/Mech General' started by Gollom, Jun 19, 2015.
  1. Gollom
    Gollom Funster
    Apr 6, 2014
    206
    122
    Preston, Lancs
    Going to replace this tomorrow. If I switch off the charger via the main control panel, can I simply remove/reconnect the battery? Do I need to take off/put back the cables in a particular order? (Terry told me that the battery also charges from the engine when it's running)
    TIA
  2. Manic
    Manic Funster
    Nov 4, 2011
    1,095
    1,201
    Uk
    It should have a fuse near the battery on the positive wire and you should remove this before starting to remove wires.
    • Like it Like it x 1
  3. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,937
    10,302
    black negative wire off first every time and last to put back on. then there is less risk of shorting. switch off charger a couple of hours before disconnecting ideally
  4. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,268
    17,931
    YO11 2BD
    No need to turn off the charger, simply unplug from hookup.
    As said, battery neg (---) terminal off first, back on last.
  5. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,301
    3,104
    Kendal, Cumbria
    ............. and if you have any solar panels disconnect them from their controller before doing anything.
    • Like it Like it x 2
